Unsupported Bits Depth Error
Post by pawanpatel »
I am getting attached error while viewing a tiff file. What may be reason for it? The windows viewer opens it perfectly.
File is here: http://www6.zippyshare.com/v/55369225/file.html
Pawan
Re: Unsupported Bits Depth Error
Hello Pawan,
Your TIFF image does not have standard information about image necessary for correct loading of image.
We will update algorithm of TIFF parser and you will be able to load your image correctly in next version of SDK.
Hello Pawan,
In version 6.1.19.3 and 7.0.0.1 we have improved TIFF decoder for compatibility with TIFF files which contain not complete info about the image, now your image file can be loaded correctly.
Thanks. I did download the version 7, but still the pages are not shown correctly. It does not throw the initial exception as it used to. But now the exception is shown in as "red" text in the viewer page itself. You can try with the sample tiff file provided in my initial post.
Note: strange thing is that "ImagingDemo.exe" shows error, while "MultipageTiffDemo.exe" shows it correctly.
Pawan
Hello Pawan,
Thank you for your message.
We have reproduced the issue, version with bug fix will be available shortly.
Hello Pawan,
Bug fix is available in version 7.0.0.3.
I confirm it is working fine.
Pawan
