Forget it. I got it to work. I was checking the HP forums and found the answer from someone on there. You have to set ShowIndicators to false before caling Acquire or AcquireModal(). It is a problem with the twain drivers from HP.
We can try to fix this problem if you send us a log-file generated by the library. Please read how to generate log-file in the documentation and send it to us. Also you can share your experience about HP scanners in the "Hardware and Vendors Discussions" forum.
