StackOverFlow Exception
Post by BillG »
private void ScanButton_Click(object sender, EventArgs e)
vsTwain1.StartDevice();
vsTwain1.ShowUI = false;
if (vsTwain1.SelectSource())
vsTwain1.MaxImages = 1;
vsTwain1.OpenDataSource();
if (vsTwain1.FeederPresent)
vsTwain1.AutoFeed = true;
vsTwain1.XferCount = -1;
if (vsTwain1.FeederLoaded)
while (vsTwain1.AcquireModal())
vsTwain1.SaveImage(0, "c:\test.tiff");
catch (TwainException ex)
MessageBox.Show(ex.Message);
vsTwain1.StopDevice();
catch (Exception ex)
I get a stackoverflow exception on the AcquireModal() function call. The scanning progress indicatior starts moving and then I get the exception.
Bill
Re: StackOverFlow Exception
Post by BillG »
Forget it. I got it to work. I was checking the HP forums and found the answer from someone on there. You have to set ShowIndicators to false before caling Acquire or AcquireModal(). It is a problem with the twain drivers from HP.
Hello Bill,
We can try to fix this problem if you send us a log-file generated by the library. Please read how to generate log-file in the documentation and send it to us. Also you can share your experience about HP scanners in the "Hardware and Vendors Discussions" forum.
Best regards, Alexangr
