I'm getting a strange error when trying to view a PDF file. The file is coming from a memory stream out of a database. The PDF in the image viewer says:
Bad or unsupported image format:
PNG predictor 255 is not supported now.
Any ideas on what the issue might be? I'm able to open other PDFs from the database without issue.
Thank you for PDF document. We reproduced the problem, fixed the bug in PDF decoder and now SDK correctly renders your PDF document.
Version with bug fix will be available this week.
