Here is C# example that shows how to read barcodes from image if image data are stored in a byte array:
/// Reads barcodes from an image. Image data are stored in a byte array.
/// <param name="reader">The reader.</param>
/// <param name="width">The width.</param>
/// <param name="height">The height.</param>
/// <param name="stride">The stride.</param>
/// <param name="format">The format.</param>
/// <param name="pixelData">The pixel data.</param>
public static Vintasoft.Barcode.IBarcodeInfo[] ReadBarcodes(
    Vintasoft.Barcode.BarcodeReader reader,
    int width,
    int height,
    int stride,
    System.Drawing.Imaging.PixelFormat format,
    byte[] pixelData)
    // lock managed data
    System.Runtime.InteropServices.GCHandle bitmapDataHandle = System.Runtime.InteropServices.GCHandle.Alloc(pixelData, GCHandleType.Pinned);
    if (!bitmapDataHandle.IsAllocated)
        throw new InvalidOperationException();
    // get IntPtr to managed data
    IntPtr pixelDataPtr = System.Runtime.InteropServices.Marshal.UnsafeAddrOfPinnedArrayElement(pixelData, 0);
        // read barcodes
        return ReadBarcodes(reader, width, height, stride, format, pixelDataPtr);
    finally
        // free GCHandle
        bitmapDataHandle.Free();
/// Reads barcodes from an image. Image data are stored in an unmanaged memory.
/// <param name="pixelDataScan0">The Scan0 pointer to pixel data.</param>
public static Vintasoft.Barcode.IBarcodeInfo[] ReadBarcodes(Vintasoft.Barcode.BarcodeReader reader, int width, int height, int stride, System.Drawing.Imaging.PixelFormat format, IntPtr pixelDataScan0)
    using (System.Drawing.Bitmap bitmap = new System.Drawing.Bitmap(width, height, stride, format, pixelDataScan0))
        // read barcodes
        return reader.ReadBarcodes(bitmap);
