/// Reads barcodes from an image. Image data are stored in a byte array.
/// <param name="reader">The reader.</param>
/// <param name="width">The width.</param>
/// <param name="height">The height.</param>
/// <param name="stride">The stride.</param>
/// <param name="format">The format.</param>
/// <param name="pixelData">The pixel data.</param>
public static Vintasoft.Barcode.IBarcodeInfo[] ReadBarcodes(
Vintasoft.Barcode.BarcodeReader reader,
int width,
int height,
int stride,
System.Drawing.Imaging.PixelFormat format,
byte[] pixelData)
// lock managed data
System.Runtime.InteropServices.GCHandle bitmapDataHandle = System.Runtime.InteropServices.GCHandle.Alloc(pixelData, GCHandleType.Pinned);
if (!bitmapDataHandle.IsAllocated)
throw new InvalidOperationException();
// get IntPtr to managed data
IntPtr pixelDataPtr = System.Runtime.InteropServices.Marshal.UnsafeAddrOfPinnedArrayElement(pixelData, 0);
// read barcodes
return ReadBarcodes(reader, width, height, stride, format, pixelDataPtr);
finally
// free GCHandle
bitmapDataHandle.Free();
/// Reads barcodes from an image. Image data are stored in an unmanaged memory.
/// <param name="pixelDataScan0">The Scan0 pointer to pixel data.</param>
public static Vintasoft.Barcode.IBarcodeInfo[] ReadBarcodes(Vintasoft.Barcode.BarcodeReader reader, int width, int height, int stride, System.Drawing.Imaging.PixelFormat format, IntPtr pixelDataScan0)
using (System.Drawing.Bitmap bitmap = new System.Drawing.Bitmap(width, height, stride, format, pixelDataScan0))
// read barcodes
return reader.ReadBarcodes(bitmap);
Forum 'Code samples'
Board index < VintaSoft Barcode < VintaSoft Barcode .NET SDK Discussions < Code samples
