Exception when aquiring 16-bit grayscale image
Post by Yiannis »
the twain ui of the EPSON scanners allow to select 8-bit grayscale, 16-bit grayscale, 24-bit color, 48-bit color.
If the user selects 16-bit grayscale an error appears and I cannot get the image.
What should I do to scan the image correctly regardless the user settings ?
Re: Exception when aquiring 16-bit grayscale image
Hello Yannis,
What transfer mode do you use? I think you use the Native transfer mode.
Acquisition of 16- and 48-bpp images are supported only in the Memory transfer mode.
