Forum 'Announcements'
Version 8.5 of VintaSoft Imaging .NET SDK has been released.
Version 8.5.11.1 of VintaSoft Imaging .NET SDK has been released.
  • Fixed the bug in algorithm that sets the value of CanMove, Can Rotate and CanResize property of composite annotation.
  • Fixed the bug in handler of AnnotationView.InteractionControllerChanging event.
  • Fixed the bug in algorithm that copies interactive fields between pages of PDF document.
  • Improved the performance of algorithm that renders radial shading pattern.
Version 8.5.12.1 of VintaSoft Imaging .NET SDK has been released.
  • Fixed the bug in algorithm that renders text-based WinForms annotations (TextAnnotation, LinkAnnotation, StampAnnotation). Now the algorithm correctly interprets symbol '\t' in annotation value.
  • Added the ability to disable rendering of Vintasoft annotations in PdfAnnotationTool class using the ShowVintasoftAnnotationAppearances property.
  • Added the ability to remove unused resources from PDF page or PDF form.
  • Optimized the algorithm of PdfFormXObjectResource.CreateFormPageRegion method.
Version 8.5.14.1 of VintaSoft Imaging .NET SDK has been released.
  • Added the ability to view images with enabled color management in ASP.NET demo applications.
  • Added the ability to specify the text formatting mode for PDF text region. In previous versions the text was always formatted according to paragraphs of PDF page. Now the text can be also divided into lines without taking paragraphs into account.
  • Added the ability to specify the minimum line width in algorithm that gets the formatted text of PDF text region.
  • Fixed the minor bug in algorithm that draws symbols of CFF font.
Version 8.5.15.1 of VintaSoft Imaging .NET SDK has been released.
  • Improved the visual text editing of interactive text fields. Now visual editor uses correct text font size and correct text quadding when interactive field is edited.
  • Improved the parser of XREF tables for correct processing of "not standard" XREF tables.
  • Fixed the bug in JavaScript interpreter. Now interpreter correctly processes the event properties for TextField.
  • Fixed the bug in generator of RadioButton view.
  • Fixed the bug in algorithm, which decodes 1-bpp image in CalGray color space.
Version 8.5.16.1 of VintaSoft Imaging .NET SDK has been released.
  • Improved the magnifier visual tool (MagnifierTool and WpfMagnifierTool):
    • added the ability to use the image processing command (filter or effect) for processing the magnifier image
    • added the ability to use the elliptical outline for the magnifier
    • added the ability to set the color and width of the magnifier border
  • Fixed the minor bug in PDF annotation tool. The bug is related with editing of ComboBox field value of PDF document interactive form.
  • Fixed the bug in algorithm that saves the DICOM annotation packet to the DICOM Presentation State file.
Page 2 from 2: 1 2
