We are proud to announce the release of new major version 8.5 of VintaSoft Imaging .NET SDK and the related Annotation, PDF,
JBIG2, JPEG2000, Document Cleanup, OCR, DICOM, and Forms Processing Plug-ins.
What's new in v8.5 of VintaSoft Imaging .NET SDK:
- Created the platform-independent web services. This allows to use Vintasoft web services on any .NET web platform, i.e. ASP.NET WebForms, ASP.NET MVC, ServiceStack, etc.
- ASP.NET MVC 5 and jQuery v2-v3 supported.
- The detailed information can be found here: https://www.vintasoft.com/vsimaging-dotnet-history.html.
What's new in v8.5 of VintaSoft PDF .NET Plug-in:
- Added the ability to verify PDF documents for compliance with standards: PDF/A-1b, PDF/A-2b, PDF/A-3b.
- Added the ability to convert PDF document into following formats: PDF/A-1b, PDF/A-2b, PDF/A-3b.
- Added the ability to work with PDF document in multiple threads (rendering, getting thumbnails, text extraction, image extraction).
- New types of PDF annotations supported: Ink, File Attachment.
- Added the Cloudy style for the following PDF annotations: polygon, rectangle, free text.
- Now PdfDocument class by default uses a controller of external fonts with fallback-font, i.e. any not found font will be replaced by default font.
- New features added to PDF Reader Demo, PDF Editor Demo and PDF Structure Editor Demo.
- The detailed information can be found here: https://www.vintasoft.com/vspdf-dotnet-history.html.
What's new in v8.5 of VintaSoft OCR .NET Plug-in:
- The used Tesseract OCR engine has been updated to version 3.04.
- Added the ability to use the Tesseract OCR engine in multithreaded environment.
- Improved the quality of text recognition in color images.
- Reduced the peak memory usage allocated during recognition of text in color images.
- The detailed information can be found here: https://www.vintasoft.com/vsocr-dotnet-history.html.
What's new in v8.5 of VintaSoft Annotation .NET Plug-in:
What's new in v8.5 of VintaSoft DICOM .NET Plug-in:
What's new in v8.5 of VintaSoft Document Cleanup .NET Plug-in:
- Created the processing command LineRecognitionCommand, which allows to perform the search of lines on the image.
- Created the processing command LineFillingCommand, which allows to fill lines in the image.
- The commands for removing and filling lines have been extended with ability to find the lines with breaks.
- The detailed information can be found here: https://www.vintasoft.com/vsdoccleanup- ... story.html.
