I have a pdf file that has a large text annotation with the font size set to 12pt.
When editing the text file the font size of the text will expand to fill the text annotation.
When exiting edit mode the font size will go back to 12pt.
Is there a way to keep the font size set for the annotation while in edit mode?
We are using the winforms .net plug-in.
I also sent an email to your support email with a copy of the pdf that I am having this issue.
Harlan.
Re: Large text annotations shows very large font in edit mode.
Thank you for your message and PDF document. We reproduced the problem and found the bug in the interactive transformer, which fills text in interactive field. The bug fix will be available in next minor release, which will be available next week. Sorry for the bug.
In version 9.0.0.15 we have fixed the bug in editor of PDF text interactive field and now SDK correctly displays text in PDF interactive field with enabled auto font size. Please use version 9.0.0.15 and let me know if you will have any question or problem.
