using System;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Media;
using Vintasoft.Imaging;
using Vintasoft.Imaging.Annotation.Wpf.UI;
using Vintasoft.Imaging.Annotation.Wpf.UI.VisualTools;
using Vintasoft.Imaging.Annotation.Wpf.UI.VisualTools.UserInteraction;
using Vintasoft.Imaging.Wpf;
using Vintasoft.Imaging.Wpf.UI;
using Vintasoft.Imaging.Wpf.UI.VisualTools.UserInteraction;
using Vintasoft.Imaging.Wpf.Utils;
namespace WpfApplication1
/// Main window.
public partial class Window1 : Window
#region Fields
/// Determines that the building process of annotation is finished.
bool _isAnnotationBuildingFinished = false;
/// Determines that the text editing must be started when text annotation is created.
bool _startTextEditingWhenTextAnnotationIsCreated = false;
#endregion
#region Constructors
/// Initializes a new instance of the <see cref="Window1"/> class.
public Window1()
InitializeComponent();
WpfAnnotationVisualTool annotationTool = annotationViewer.AnnotationVisualTool;
annotationTool.AnnotationBuildingFinished +=
new EventHandler<WpfAnnotationViewEventArgs>(annotationTool_AnnotationBuildingFinished);
annotationTool.ActiveInteractionControllerChanged +=
new PropertyChangedEventHandler<IWpfInteractionController>(annotationTool_ActiveInteractionControllerChanged);
#endregion
#region Methods
/// Raizes event <see cref="E:System.Windows.Window.Closed" />.
annotationViewer.Images.ClearAndDisposeItems();
base.OnClosed(e);
/// Loads images to viewer.
private void loadImage_Click(object sender, RoutedEventArgs e)
// if building of annotation is not finished
if (!_isAnnotationBuildingFinished)
annotationTool.CancelAnnotationBuilding();
// remove all images
Microsoft.Win32.OpenFileDialog dialog = new Microsoft.Win32.OpenFileDialog();
dialog.InitialDirectory = Environment.GetFolderPath(Environment.SpecialFolder.MyPictures);
dialog.Filter = "Jpeg file|*.jpg;*.jpeg|Tiff file|*.tiff;*.tif|Png file|*.png|Bmp file|*.bmp";
if (dialog.ShowDialog(this) == true)
// load images
annotationViewer.Images.Add(dialog.FileName);
catch (Exception exc)
MessageBox.Show(exc.Message, "Error", MessageBoxButton.OK, MessageBoxImage.Error);
addTextAnnotation.IsEnabled = annotationViewer.Image != null;
/// Adds text annotation.
private void addTextAnnotation_Click(object sender, RoutedEventArgs e)
// create text annotation
TextAnnotationData textAnnotation = new TextAnnotationData();
textAnnotation.Text = "Text";
textAnnotation.FontBrush = new AnnotationSolidBrush(System.Drawing.Color.DarkGreen);
textAnnotation.FillBrush = new AnnotationSolidBrush(System.Drawing.Color.LightGray);
textAnnotation.Border = true;
textAnnotation.Outline.Width = 5;
textAnnotation.Outline.Brush = new AnnotationSolidBrush(System.Drawing.Color.Blue);
// build annotation
annotationTool.AddAndBuildAnnotation(textAnnotation);
private void startTextEditingCheckBox_Checked(object sender, RoutedEventArgs e)
_startTextEditingWhenTextAnnotationIsCreated = (bool)startTextEditingCheckBox.IsChecked;
/// Building of annotation is finished.
private void annotationTool_AnnotationBuildingFinished(object sender, WpfAnnotationViewEventArgs e)
_isAnnotationBuildingFinished = true;
if (_startTextEditingWhenTextAnnotationIsCreated &&
e.AnnotationView is WpfTextAnnotationView)
e.AnnotationView.InteractionControllerChanged +=
new PropertyChangedEventHandler<IWpfInteractionController>(TextAnnotation_InteractionControllerChanged);
/// The interaction controller of text annotation is changed.
void TextAnnotation_InteractionControllerChanged(object sender, PropertyChangedEventArgs<IWpfInteractionController> e)
WpfRectangularTextAnnotationTransformer transformer =
e.NewValue as WpfRectangularTextAnnotationTransformer;
if (transformer != null)
WpfAnnotationView view = (WpfAnnotationView)sender;
transformer.ShowTextBox(annotationViewer, new Point(0, 0));
TextBox textBox = transformer.TextBox;
textBox.Focus();
textBox.Select(textBox.Text.Length, 0);
textBox.ScrollToEnd();
view.InteractionControllerChanged -=
/// The interaction controller of annotation is changed.
private void annotationTool_ActiveInteractionControllerChanged(object sender,
if (e.OldValue is WpfRectangularTextAnnotationTransformer)
(WpfRectangularTextAnnotationTransformer)e.OldValue;
transformer.TextBoxTransformer.TextBoxUpdated -=
new EventHandler<WpfTextObjectTextBoxTransformerEventArgs>(TextBoxTransformer_TextBoxUpdated);
if (e.NewValue is WpfRectangularTextAnnotationTransformer)
(WpfRectangularTextAnnotationTransformer)e.NewValue;
WpfTextObjectTextBoxTransformer textBoxTransformer = transformer.TextBoxTransformer;
if (startTextEditingOneClickRadioButton.IsChecked == true)
textBoxTransformer.ActivateClickCount = 1;
else if (startTextEditingDoubleClickRadioButton.IsChecked == true)
textBoxTransformer.ActivateClickCount = 2;
textBoxTransformer.TextBoxUpdated +=
/// Updates the text box of text annotation.
void TextBoxTransformer_TextBoxUpdated(object sender, WpfTextObjectTextBoxTransformerEventArgs e)
TextBox textBox = e.TextBox;
WpfTextAnnotationView annotationView = (WpfTextAnnotationView)e.TextObject;
Scale scaleToImage = e.Viewer.ViewerState.ScaleToImage;
Resolution imageResolution = e.Viewer.Image.Resolution;
Scale textBoxScale = new Scale(
(float)(scaleToImage.Horizontal * (imageResolution.Horizontal / 96.0)),
(float)(scaleToImage.Vertical * (imageResolution.Vertical / 96.0)));
// update colors of text box
UpdateTextBoxColors(textBox, annotationView, textBoxScale);
// update font of text box
UpdateTextBoxFontStyle(textBox, annotationView, textBoxScale);
// update location and size of text box
UpdateTextBoxLocationAndSize(textBox, annotationView, e.Viewer, textBoxScale);
/// Updates colors of the text box.
/// <param name="textBox">The text box.</param>
/// <param name="annotationView">The annotation view.</param>
/// <param name="textBoxScale">The scale of the text box.</param>
private void UpdateTextBoxColors(TextBox textBox, WpfTextAnnotationView annotationView, Scale textBoxScale)
// if background color is solid
if (annotationView.FillBrush is AnnotationSolidBrush)
// get brush
AnnotationSolidBrush solidBrush = (AnnotationSolidBrush)annotationView.FillBrush;
// create solid brush
textBox.Background = new SolidColorBrush(WpfObjectConverter.CreateWindowsColor(solidBrush.Color));
// if font color is solid
if (annotationView.FontBrush is AnnotationSolidBrush)
// get brush
AnnotationSolidBrush solidBrush = (AnnotationSolidBrush)annotationView.FontBrush;
textBox.Foreground = new SolidColorBrush(WpfObjectConverter.CreateWindowsColor(solidBrush.Color));
// create thickness of border
Thickness borderThickness = new Thickness();
// create brush of border
SolidColorBrush borderBrush = new SolidColorBrush(Colors.Transparent);
// if border is visible
if (annotationView.Border)
// create brush
WpfObjectConverter.CreateWindowsColor(annotationView.Outline.Color));
// get border width
double width = annotationView.Outline.Width;
width * textBoxScale.Horizontal,
width * textBoxScale.Vertical,
width * textBoxScale.Vertical);
// update thickness of border
textBox.BorderThickness = borderThickness;
// update brush of border
textBox.BorderBrush = borderBrush;
/// Updates font style of the text box.
private void UpdateTextBoxFontStyle(
TextBox textBox,
Scale textBoxScale)
AnnotationFont font = annotationView.Font;
// create font family of text
textBox.FontFamily = new FontFamily(font.FamilyName);
// calculate font size
double fontSize = font.Size * textBoxScale.Horizontal;
// convert font size to device independent pixels
switch (font.Unit)
case AnnotationFontUnit.Display:
fontSize *= 96.0 / ImagingEnvironment.ScreenDpiX;
break;
case AnnotationFontUnit.Document:
fontSize *= 96.0 / 300;
break;
case AnnotationFontUnit.Inch:
fontSize *= 96.0;
break;
case AnnotationFontUnit.Millimeter:
fontSize *= 96.0 / 25.4;
break;
case AnnotationFontUnit.Point:
fontSize *= 96.0 / 72;
break;
textBox.FontSize = fontSize;
// if font is italic
if (font.Italic)
textBox.FontStyle = FontStyles.Italic;
// if font is bold
if (font.Bold)
textBox.FontWeight = FontWeights.Bold;
// if font is strikeout
if (font.Strikeout)
TextDecoration strikeout = new TextDecoration();
strikeout.Location = TextDecorationLocation.Strikethrough;
textBox.TextDecorations.Add(strikeout);
// if font is underline
if (font.Underline)
TextDecoration underline = new TextDecoration();
underline.Location = TextDecorationLocation.Underline;
textBox.TextDecorations.Add(underline);
/// Updates the size and location of the text box.
/// <param name="viewer">The viewer.</param>
private void UpdateTextBoxLocationAndSize(
TextBox textBox,
WpfImageViewer viewer,
Scale textBoxScale)
// update horizontal alignment of text
switch (annotationView.TextHorizontalAlignment)
case AlignmentX.Center:
textBox.HorizontalContentAlignment = HorizontalAlignment.Center;
break;
case AlignmentX.Left:
textBox.HorizontalContentAlignment = HorizontalAlignment.Left;
break;
case AlignmentX.Right:
textBox.HorizontalContentAlignment = HorizontalAlignment.Right;
break;
// update vertical alignment of text
switch (annotationView.TextVerticalAlignment)
case AlignmentY.Bottom:
textBox.VerticalContentAlignment = VerticalAlignment.Bottom;
break;
case AlignmentY.Center:
textBox.VerticalContentAlignment = VerticalAlignment.Center;
break;
case AlignmentY.Top:
textBox.VerticalContentAlignment = VerticalAlignment.Top;
break;
// get point transform of the annotation for image viewer
WpfPointTransform transform = annotationView.GetPointTransform(viewer);
// location of annotation
Point location = annotationView.Location;
// size of annotation
Size size = annotationView.Size;
// calculate top-left point of annotation
Point topLeftPoint = new Point(location.X - size.Width / 2, location.Y - size.Height / 2);
topLeftPoint = transform.TransformPoint(topLeftPoint);
// calculate bottom-right point of annotation
Point bottomRightPoint = new Point(location.X + size.Width / 2, location.Y + size.Height / 2);
bottomRightPoint = transform.TransformPoint(bottomRightPoint);
// calculate bounding box of text box
double textBoxX = topLeftPoint.X;
double textBoxY = topLeftPoint.Y;
double textBoxWidth = bottomRightPoint.X - topLeftPoint.X;
double textBoxHeight = bottomRightPoint.Y - topLeftPoint.Y;
if (textBoxWidth <= 0)
textBoxWidth = 0;
if (textBoxHeight <= 0)
textBoxHeight = 0;
Canvas.SetLeft(textBox, textBoxX);
Canvas.SetTop(textBox, textBoxY);
textBox.Width = textBoxWidth;
textBox.Height = textBoxHeight;
// calculate padding of text
double textPaddingLeft = annotationView.TextPadding.Left * textBoxScale.Horizontal;
double textPaddingTop = annotationView.TextPadding.Top * textBoxScale.Vertical;
double textPaddingRight = annotationView.TextPadding.Right * textBoxScale.Horizontal;
double textPaddingBottom = annotationView.TextPadding.Bottom * textBoxScale.Vertical;
// if border is not visible
if (!annotationView.Border)
double borderHorizontal = annotationView.Outline.Width * textBoxScale.Horizontal;
double borderVertical = annotationView.Outline.Width * textBoxScale.Vertical;
// update padding of text
textPaddingLeft += borderHorizontal;
textPaddingTop += borderVertical;
textPaddingRight += borderHorizontal;
textPaddingBottom += borderVertical;
textBox.Padding = new Thickness(
textPaddingLeft,
textPaddingTop,
textPaddingRight,
textPaddingBottom);
// if annotation is mirrored
if (annotationView.HorizontalMirrored ||
annotationView.VerticalMirrored)
// create transform
TransformGroup layoutTransform = new TransformGroup();
// if annotation is horizontal mirrored
if (annotationView.HorizontalMirrored)
layoutTransform.Children.Add(new ScaleTransform(-1, 1));
// if annotation is vertical mirrored
if (annotationView.VerticalMirrored)
layoutTransform.Children.Add(new ScaleTransform(1, -1));
textBox.LayoutTransform = layoutTransform;
// if annotation is rotated
if (annotationView.Rotation != 0)
// rotate annotation at center of annotation
textBox.RenderTransformOrigin = new Point(0.5, 0.5);
textBox.RenderTransform = new RotateTransform(annotationView.Rotation);
private void startTextEditingClickRadioButton_Checked(object sender, RoutedEventArgs e)
if (annotationViewer == null)
return;
IWpfInteractionController controller =
annotationViewer.AnnotationVisualTool.ActiveInteractionController;
if (controller is WpfRectangularTextAnnotationTransformer)
(WpfRectangularTextAnnotationTransformer)controller;
#endregion
Source codes of WPF application for VintaSoft Imaging .NET SDK 14.0 can be downloaded here.
