Zoom not changing
Zoom not changing
Post by rstrickland1958 »
I am currently reviewing the tool for a customer looking to convert to WPF with a need for imaging controls. I have a simple WPF view with the WpfAnnotationViewer in the grid. I successfully loaded an image in the viewer. I now want to zoom in to 45 but when I change the zoom property nothing happens. I an using the WpfAnnotationDemo to see how this works where the view using a slider to adjust in or out on the image. I know I am missing a setting somewhere but not sure where to start.
Re: Zoom not changing
The WpfImageViewer.Zoom property allows to change image zoom in image viewer:
https://www.vintasoft.com/docs/vsimagin ... /Zoom.html
Have you tried to use the WpfImageViewer.Zoom property?
Yes. That was the property that I was setting. Note code below:
this.documentViewer.Zoom = 100;
I got the zooming to work after setting the SizeMode to the WpfAnnotationViewer to 'Zoom'.
Is this correct way to get Zoom to work?
Yes, this is correct. You need set the WpfImageViewer.SizeMode property to the ImageSizeMode.Zoom and specify the zoom using the WpfImageViewer.Zoom property.
Thanks.
