What's new in this version:
- Now the barcode reading and writing functionality can be very easily added into a web application:
- Vintasoft.Barcode.Web.HttpHandlers assembly may be used on server side of an ASP.NET application and allows to create an HTTP handler for barcode recognition and generation.
- Vintasoft.Barcode.Web.WcfServices assembly may be used on server side of an ASP.NET application and allows to create a WCF service for barcode recognition and generation.
- Vintasoft.Barcode.Web.ApiControllers assembly may be used on server side of an ASP.NET MVC application and allows to create a Web controller for barcode recognition and generation.
- Vintasoft.Barcode.js file written in JavaScript may be used on client side of an ASP.NET application and includes the classes and enumerations, which simplify the reading and writing of barcodes.
- Improved the recognition algorithm of Code 128, EAN, RSS/GS1, Aztec, HanXin and MaxiCode barcodes.
- Improved the DataMatrix barcode recognition algorithm. Now it is possible to recognize DataMatrix barcodes with different cell widths.
- Improved the QR Code barcode recognition algorithm:
- Now the algorithm can read QR barcodes with large axial non-uniformity, i.e. unproportional QR Code barcodes.
- Added new property – ReaderSettings.QRMaxAxialNonuniformity that allows to specify maximum permitted axial non-uniformity taking place in a QR barcode. The QR Code barcode recognition speed since could be greatly increased unless the barcode has axial non-uniformity.
- Improved the error correction algorithm for 2D barcodes.
- Fixed the bug in algorithm that calculates the FixedPatternDamage parameter for ISO15415 barcode print quality test.
- Fixed the bug in deserialization of ReaderSettings.ThresholdIterations property. The maximum allowable value of ReaderSettings.ThresholdIterations property is extended up to 75.
- AspNetMvcBarcodeDemo - the new ASP.NET MVC demo application has been created. It demonstrates how to recognize and generate barcodes in ASP.NET MVC. The application references Vintasoft.Barcode.Web.ApiControllers assembly and Vintasoft.Barcode.js file.
