List<VintasoftImage> images = new List<VintasoftImage>();
VintasoftImage imagem = new VintasoftImage(path + fileName + ext);
imagem.RenderingSettings = new RenderingSettings(new Resolution(96 * fator, 96 * fator), InterpolationMode.HighQualityBicubic, SmoothingMode.HighQuality);
FormRecognitionManager = new FormRecognitionManager();
FormRecognitionManager.FormTemplates.LoadFromDocument(pathTemplate + template + extTemplate);
images.Add(imagem);
FormDocumentTemplate FormDocumentTemplate = FormDocumentTemplate.Deserialize(pathTemplate + template + extTemplate);
public static String PreprocessAndOcrImages(FormDocumentTemplate FormDocumentTemplate, OcrLanguage language, string filename)
String resultado = "";
//Hashtable resultado = new Hashtable();
List<RecognitionRegion> regions = new List<RecognitionRegion>();
List<FormFieldTemplate> campos = (FormDocumentTemplate.Pages[0].Items[0] as Vintasoft.Imaging.FormsProcessing.FormRecognition.FormFieldTemplateGroup).Items.ToList();
foreach(FormFieldTemplate campo in campos){
int x = (int)campo.BoundingBox.X*fator;
int y = (int)campo.BoundingBox.Y*fator;
int w = (int)campo.BoundingBox.Width*fator;
int h = (int)campo.BoundingBox.Height*fator;
regions.Add(new RecognitionRegion(new RegionOfInterest(x, y, w, h),language));
// load image(s)
VintasoftImage imagem = new VintasoftImage(filename);
images.Add(imagem);
//Console.WriteLine("Create Tesseract OCR engine...");
using (TesseractOcr tesseractOcr = new TesseractOcr(TesseractOcrDllDirectory))
// create OCR engine manager
OcrEngineManager engineManager =
new OcrEngineManager(tesseractOcr);
OcrEngineSettings settings = new OcrEngineSettings(language);
// foreach image
foreach (VintasoftImage image in images)
//Console.WriteLine("Preprocess image:");
//Console.WriteLine("BorderClear, Despeckle, Deskew, Segmentation...");
OcrPreprocessingCommand preprocessing = new OcrPreprocessingCommand();
preprocessing.Binarization = null;
preprocessing.ExecuteInPlace(image);
//Console.WriteLine("Recognize image...");
//OcrPage page = engineManager.Recognize(image, settings, preprocessing.SegmentationTextRegions);
OcrPage page = engineManager.Recognize(image, settings, regions);
//Console.WriteLine("Page Text:");
//Console.WriteLine(page.GetText());
Console.WriteLine();
//for (int i = 0; i < page.Regions.Count; i++)
// Rectangle ret = new Rectangle(
// (int)campos[i].BoundingBox.X * fator,
// (int)campos[i].BoundingBox.Y * fator,
// (int)campos[i].BoundingBox.Width * fator,
// (int)campos[i].BoundingBox.Height * fator);
// Object[] obj= page.GetObjects(OcrObjectType.TextRegion, ret);
// var dados = obj==null ||obj.Length==0 ?"":(obj[0] as OcrTextRegion).Text.Trim();
// resultado.Add(campos[i].Name,dados);
resultado += page.GetText();
// free resources
images.Dispose();
return resultado;
the project sample is a desktop application , this turn out the task hard, understand a code with desktop components associate.VintaSoft provides detailed online documentation with code samples. Try to read this article, it contains essentials of forms recognition and contains several code samples reusable in console applications. The example of "RecognizeFormWithOcrFields" method might be helpful for you.
i need a code project type "console application"
//i use the variable "fator" ,because the resolution of image was modified when i created the "template"
static int fator = 10;
static ChangePixelFormatToBlackWhiteCommand _binarizeCommand = new ChangePixelFormatToBlackWhiteCommand(BinarizationMode.Global);
// the other variables are just paths of the images,of the tesseract and others.
static void Main(string[] args){
FormDocumentTemplate templateDocument = FormDocumentTemplate.Deserialize(pathTemplate + template + extTemplate);
FormRecognitionManager.FormTemplates.LoadFromDocument(templateDocument);
#region template
RenderingSettings _renderingSettings = new RenderingSettings(new Resolution(fator * 96, fator * 96), InterpolationMode.HighQualityBicubic, SmoothingMode.HighQuality);
//// images to remove from template manager
List<VintasoftImage> imagesToRemove = new List<VintasoftImage>();
for (int i = 0; i < templateDocument.Pages.Count; i++)
// // current page template
FormPageTemplate templatePage = templateDocument.Pages[i];
// // get corresponding template image
VintasoftImage templateImage = FormRecognitionManager.FormTemplates.GetTemplateImage(templatePage);
if (templateImage.PixelFormat != Vintasoft.Imaging.PixelFormat.BlackWhite)
ProcessingCommandBase processingCommand = null;
templateImage.RenderingSettings = _renderingSettings;
processingCommand = _binarizeCommand;
// if processing command is set
if (processingCommand != null)
bool processingError = false;
processingCommand.ExecuteInPlace(templateImage);
catch (Exception ex)
Console.WriteLine(ex.Message);
templateImage.Dispose();
processingError = true;
if (processingError)
continue;
#endregion
#region arquivo pdf
List<string> filenames = new List<string>();
filenames.Add(path + fileName + ext);
//// for each selected file
ImageCollection filledImages = new ImageCollection();
foreach (string filename in filenames)
// // temporary image collection for all images in current file
filledImages.Add(filename);
foreach (VintasoftImage image in filledImages)
// if binarization is canceled
if (image.PixelFormat != Vintasoft.Imaging.PixelFormat.BlackWhite)
// if settings shall be applied for all remaining images or
// settings are approved
image.RenderingSettings = _renderingSettings;
processingCommand.ExecuteInPlace(image);
image.Dispose();
continue;
RecognizeFormWithOcrFields(FormRecognitionManager, image);
filledImages.Clear();
#endregion
OcrEngine ocrEngine = new TesseractOcr(TesseractOcrDllDirectory); OcrFieldTemplate.OcrEngineManager = new OcrEngineManager(ocrEngine);
