Forum 'Announcements'
Version 8.2 of VintaSoft Imaging .NET SDK has been released.
We are proud to announce the release of new major version 8.2 of VintaSoft Imaging .NET SDK and the related Annotation, PDF, JBIG2, JPEG2000, Document Cleanup, OCR, DICOM Plug-ins and the brand new Forms Processing Plug-in.
  • Created a brand new VintaSoft Forms Processing .NET Plug-in, which provides the templates recognition, forms alignment and OMR (optical mark recognition).
  • Added the broad support for working with interactive PDF forms: Push button, Text, List Box, Combo Box, Check Box, Radio Button, Signature Field, Barcode Field.
  • Added the ability to sign PDF documents with digital signature and work with signatures.
  • Extended the list of supported web annotations.
  • Added the ability to transform the line-based web annotation by points.
  • In Web Annotation Demo is added the ability to change properties of web annotation using web property grid.
Version 8.2.1.1 of VintaSoft Imaging .NET SDK has been released.
  • Fixed not citical bug in JPEG decoder.
  • Improved algorithm that restores damaged PDF documents.
  • Improved algorithm that generates appearance of Link annotation.
  • Fixed not critical bug in decoder of image-resources.
Version 8.2.2.1 of VintaSoft Imaging .NET SDK has been released.
  • Added the ability to rotate JPEG image orthogonally without quality loss (only if image width is multiple of 16).
  • Some minor fixes.
  • Fixed bug in parser of PDF page.
  • Fixed bug in extraction of formatted text from PDF page.
Version 8.2.3.1 of VintaSoft Imaging .NET SDK has been released.
  • Many improvements in web image viewer.
  • Many improvements in web thumbnail viewer.
  • Added the ability to use touch input for editing annotations in web annotation viewer.
  • Many minor fixes in web controls.
  • Improved the user interface of all web demo applications.
Version 8.2.4.1 of VintaSoft Imaging .NET SDK has been released.
  • Added ability to override search algorithm of CID fonts and use custom CID font instead of CID font from PDF document if CID font from PDF document is not found.
  • Added support of OpenType fonts.
Version 8.2.5.1 of VintaSoft Imaging .NET SDK has been released.
  • SDK was successfully tested in Windows 10 and Visual Studio 2015.
  • Increased the performance of web viewers when web viewers is used for previewing “big” multipage files (500 and more pages).
  • Fixed minor bug in TIFF decoder.
  • Increased the rendering speed of PDF documents which contain image-resources with big JPEG images.
  • Added progressive rendering of image-resources with progressive JPEG images in PDF documents.
Version 8.2.6.1 of VintaSoft Imaging .NET SDK has been released.
  • In WpfImagePrintManager class added the ability to process image before printing. This can be useful if color image is printed on black-white printer.
  • In WpfImagePrintManager class added the ability to print image with resolution different from printer resolution. This can be useful if printer has very high resolution.
  • Fixed not critical memory leak that may occur only if application loads lots of annotations.
  • Improved the algorithm that extract text from PDF document.
  • Improved the algorithm that restores damaged PDF documents.
  • Fixed minor regress in PDF renderer.
  • Fixed minor bug that occurred when rotated PDF annotations merged with content of PDF page.
Version 8.2.7.1 of VintaSoft Imaging .NET SDK has been released.
Version 8.2.7.3 of VintaSoft Imaging .NET SDK has been released.
  • Fixed the bug in decoder of TIFF files.
  • Fixed the bug in parser of PDF documents.
  • Fixed the bug in algorithm that extract text from PDF page.
  • Fixed the bug which may occur during text recognition in large images with noise.
Version 8.2.8.1 of VintaSoft Imaging .NET SDK has been released.
  • Fixed the bug in PDF page renderer.
Version 8.2.9.1 of VintaSoft Imaging .NET SDK has been released.
Page 1 from 2: 1 2
