Wrong Image Size ??
Wrong Image Size ??
Post by DuempertM »
i have an problem with a speficied Image.
I added this image to the Wpf Image Viewer and the result is to small.
In all other Image Viewer Programs shows the image correctly.
You can reproduce in Sample Code from WpfImaging Demo Project.
The Image File can you downloading from this link...
http://www.wpm-ingenieure.de/downloads/image.jpg
Whats wrong ?
Re: Wrong Image Size ??
By default image viewer shows image in Normal mode, i.e. viewer takes into consideration display resolution (96 dpi) and image resolution (300 dpi). You can use PixelToPixel mode if you want to show image as is. More info please read here: https://www.vintasoft.com/docs/vsimaging ... n_Wpf.html
Post by DuempertM »
Okay thank you.
