PDF Security
PDF Security
Post by kwaltman »
I am trying to set the security settings on a document. But the .EncryptionSystem property object and all of it's properties on a PDFDocument are readonly. How does one set the actual properties. Ifs there another method that has to be used to set the properties?
Re: PDF Security
Post by vladimirG »
kwaltman,
you can use constructors to create new objects with desired properties. Here is an example:
EncryptionSystem encSystem = new EncryptionSystem(
    EncryptionAlgorithm.RC4, 40, "userpwd", "ownerpwd", UserAccessPermissions.ExtractTextAndGraphics);
using (PdfDocument document = new PdfDocument(PdfFormat.Pdf_16, encSystem))
    document.Pages.Add(PaperSizeKind.A4);
    document.Save(filename);
encSystem.Dispose();
If you want to change security properties of an existing PDF document, do it in the same way. The following code should work:
using (PdfDocument documentOriginal = new PdfDocument(inFilename))
using (PdfDocument documentChanged = new PdfDocument(PdfFormat.Pdf_16, encSystem))
    documentChanged.Pages.AddRange(documentOriginal.Pages.ToArray());
    documentChanged.Save(outFilename);
