I'm using a Kodak i2600. My scanning is set to memory transfer mode: when I set PixelType to BW or Gray, everything is okay. But, when I set to RGB, the following event is producing an empty file, 0kb file...
private void _device_ImageAcquired(object sender, ImageAcquiredEventArgs e)
var filename ='test.jpg";
if (!e.Image.IsBlank(0.01f))
e.Image.Save(filename);
I don't know what is wrong.... someone could point some direction? thank you
