Acquire more than one page - with user-interaction
Post by mierli »
Hello
I have a question to the "Acquire"-process - like your example:
            int imageIndex = 0;
            do
                acquireModalState = device.AcquireModal();
                switch (acquireModalState)
                        // save image to file
                        device.AcquiredImages.Last.Save(multipageTiffFilename);
                        // output current state
                        Console.WriteLine(string.Format("Image{0} is saved.", imageIndex++));
                        break;
                        // close device and device manager
                        CloseDeviceAndDeviceManager(deviceManager, device);
                        Console.WriteLine("Scan completed.");
                        break;
                        Console.WriteLine("Scan canceled.");
                        break;
                        Console.WriteLine(string.Format("Scan failed: {0}", device.ErrorString));
                        break;
I want create a user-dialog, that asks the user after every acquired page "scan complete? or another page...." - and if the user press the button "scan complete", the application saves the current document; if the user press the button "another page / or next page" the acquire-process should be continued.
How can I solve this issue?
Please have you a clue for my question?
Many thanks in advance for any help & best regards
Michael
Re: Acquire more than one page - with user-interaction
Hello Michael,
Do you want to create the user dialog for flatbed scanner, scanner with ADF or for any scanner?
Post by mierli »
Hello Alexander
I think for any scanner - but what has to do with the user-dialoge?`
Thanks & best regards
Michael
Hello Michael,
Your algorithm should do the following steps:
  • Start an image acquisition
  • Show a user dialog when image is acquired
  • Cancel OR finish image acquisition if user does not want to acquire more images
  • Start new image acquisition process OR continue current image acquisition process if user wants to acquire more images
Please read how to cancel the image acquisition process here:
https://www.vintasoft.com/docs/vstwain-d ... ition.html
