When I call Device.open, I get a Twain Error: "General failure in response to DAT_CAPS. Bad protocol error."
This happens in my own code, but also in the demos provided by VintaSoft. The error is shown in a message box, displayed by the scanner software.
My scanner is a VistaScan, used to scan dental radiographies, so not a very common equipment.
After I close the message, scanning proceeds and I can acquire the images.
My setup: Windows 8 64bits, VintaSoftTwain.NET SDK 8.3 (x86), scanner uses Twain 1.9. Same problem happens on a Windows 7 machine. I have tried changing various parameters, to no avail.
I'm about to purchase Vintasoft's solution, but cannot until this problem is solved. Please, can someone help me?
Please generate log-file and send it to our support team at support@vintasoft.com for analyze.
Here are steps which you should do if you want to generate an extended log-file of scanner's work:
1. Enable logging (add the lines below to code of your application):
TwainEnvironment.EnableDebugging("d:\vstwain.log")
TwainEnvironment.DebugLevel = DebugLevel.Debug
2. Run your application.
3. Send us a log-file and detailed description of the problem.
