How To: Export a certain page of PDF to JPG file.
Post by tjimenez »
We are testing your "VintaSoftPDF.NET SDK" & "VintaSoftImaging.NET SDK" to get the following:
Create a JPG file from a page of PDF file, similary to your "Document > Save Current Page As..." from "VintaSoft PDF Reader Demo v3.1"
If we have next portion of code:
_fileStream.Position = 0
openFileThread.Start()
_isFirstOpenedPage = True
If _document.IsEncrypted Then
    Text += " (SECURED)"
firstPage = 1
        strNombreArchivoJPG = "PAG_" & Format(pageNo, "000") & ".jpg"
Next
We have been reviewing the help, not just find a way to do this easily, without being as complicated as the example.
Can you help us ?
Thanks.
Re: How To: Export a certain page of PDF to JPG file.
Your code does not have part where you save image of PDF page to JPEG file.
Here is an example that shows how to save each PDF page as JPEG file using image collection and JpegEncoder:
Imports System.IO
Imports Vintasoft.Imaging
Imports Vintasoft.Imaging.Codecs
Module Module1
    Sub Main()
        SavePdfPagesAsJpeg("d:\PdfTest.pdf", "d:\jpegDir\")
    End Sub
    Public Sub SavePdfPagesAsJpeg(ByVal pdfFileName As String, ByVal jpegDir As String)
        ' create image collection
        Dim imageCollection As New ImageCollection()
        ' add PDF document to collection
        imageCollection.Add(pdfFileName)
        ' create JpegEncoder
        Dim jpegEncoder1 As New JpegEncoder()
        ' set quality of output JPEG files
        jpegEncoder1.Settings.Quality = 90
        ' save images of image collection to TIFF file using TiffEncoder
        Dim vsImage as VintasoftImage
        For i As Integer = 0 To imageCollection.Count - 1
            ' get image of PDF page as VintasoftImage object
            vsImage = imageCollection(i)
            ' save VintasoftImage object as JPEG file
            vsImage.Save(Path.Combine(jpegDir, String.Format("page{0}.jpg", i)), jpegEncoder1)
        Next
        ' free resources
        jpegEncoder1.Dispose()
        imageCollection.Dispose()
    End Sub
End Module
Here is an example that shows how to save each PDF page as JPEG file using PdfDocument and VintasoftImage:
Imports System.IO
Imports Vintasoft.Pdf
Module Module1
    Sub Main()
    End Sub
        ' open existing PDF document
        Dim pdfDocument As New PdfDocument(pdfFileName)
        ' for each PDF page
        For i As Integer = 0 To pdfDocument.Pages.Count - 1
            Using vsImage As VintasoftImage = pdfDocument.Pages(i).Render()
                vsImage.Save(Path.Combine(jpegDir, String.Format("page{0}.jpg", i)))
            End Using
        Next
        ' free resources
        pdfDocument.Dispose()
    End Sub
End Module
Post by tjimenez »
Okay, it's a lot easier than I thought.
Thank you very much for your efficiency.
Post by tjimenez »
Ok, I'll do something like this, but adding JPEGencoder :
Imports System.IO
Module Module1
    Sub Main()
    End Sub
        Dim JPEGencoder As New JpegEncoder()
        JPEGencoder.Settings.Quality = 90
        JPEGencoder.Settings.SaveAsGrayscale = False
        ' for each PDF page
                vsImage.Save(Path.Combine(jpegDir, String.Format("page{0}.jpg", i)), JPEGencoder)
            End Using
        Next
        ' free resources
    End Sub
End Module
This works fine, but.. How to set DPI to 150, for example ?
Thanks for advance.
You need change the rendering settings of PDF document if you want to render PDF pages with custom settings.
Here is an example:
pdfDocument.RenderingSettings.Resolution = New Resolution(150, 150)
Post by tjimenez »
It works perfect, Alex !!!
Thanks!
I have not been able to find this information in the "Vintasoft.Imaging.chm".
At least, in a way so clear as you explain ...
Have you got any document with more information than this one ?
Thank you for appreciating of my explanations.
Developer can get information from many sources: We continuously improve and extend our documentation. New version of documentation will be available with version 7.0 of SDK.
Please ask your questions and we will explain how to solve your task in the best way.
