Also a constructor for PDFPage which accepts common document sizes like A4, A5, Letter and so on.Now you can use the PdfPage(PdfDocument document, Rectangle size) constructor and create page of any size.
I wanted to ask if there is a chance, that my feature request for word and character spacing and for adjusting the vertical position of text for version 3.0 is considered?I'm not sure I have understand you. Do you want to be able to change position and spacing of symbols and words on PDF page? I think this will be possible in version 6.0.
I hope Version 6.0 will be available soon.I hope at the end of the summer.
Is it right, that version 3.0 of VintasoftPDF.NET only works with Version 6.0 of VintasoftImaging.NET SDK?Each plug-in has sub version, the sub version number depends from the release date of plug-in.
Also a constructor for PDFPage which accepts common document sizes like A4, A5, Letter and so on.Done.
Support for word and character spacing and for adjusting the vertical position of text would be great.Done.
