Set Annotation visible false
Post by MichaelHerrmanns »
I want to write a function to switch all annotations of a image to visible false or true.
For this I use this code:
Dim images As ImageCollection = AnnotationViewer1.Images
        Dim annotations As AnnotationController = New AnnotationController(images)
        Dim imageIndex As Integer, annoIndex As Integer
        For imageIndex = 0 To images.Count - 1
            Dim imageAnnotations As AnnotationCollection = annotations(imageIndex)
            For annoIndex = 0 To imageAnnotations.Count - 1
                Debug.Print(imageAnnotations(annoIndex).Visible.ToString)
                imageAnnotations(annoIndex).Visible = Not imageAnnotations(annoIndex).Visible
            Next annoIndex
        Next imageIndex
But I must reload the image to see the annoations visible false/true.
Any idea
regards
Michael
Re: Set Annotation visible false
Hello Michael,
Your code has logical mistake - you need to use annotation controller associated with annotation viewer instead of creating new annotation controller.
Here is your code:
and here is correct code:
Dim annotations As AnnotationController = annotationViewer1.Annotations
Thank you very much.
Now it is working.
Best regards
Michael
