The benefits of a Jbig2 compression for a pdf file
Post by stefanp2011 »
We are evaluating the Jbig2 compression. We read about this format and we understood that the size of a pdf file can be dramatically decreased by using this format.
Do you have a demo/script which can take a pdf as input, compress it without quality losses, using Jbig2, into another pdf document, and give back this pdf?
Re: The benefits of a Jbig2 compression for a pdf file
Hello Stefan,
You can do this using our Image Converter Demo:
  • select input PDF document
  • specify output PDF document
  • Press the "Convert" button
  • Select JBIG2 compression in "PDF save settings" dialog
  • Select necessary parameters of JBIG2 compression
  • Press the "Ok" button
