If the progress value in UpdateSavingImagesProgress = 100, does that do it? I noticed that this value will hit 100 without running through the function above (for example when rotating a page) but the changes are not saved back to the source file until the code in that function is run.100% progress means that all images from image collection were processed. You must subscribe to the ImageCollectionSaved event if you want to know when image collection was saved.
AddHandler encoder.ImageCollectionSaved, New ImageCollectionSavedEventHandler(AddressOf encoder_ImageCollectionSaved)is raised (which finally ends up in the sub ChangeSourceStreamToSaveStream), I can safely assume the image collection is saved and the file is ready to be closed and moved.
hi,is it invalid yet:-?What do you mean?
