Forum 'Hardware and Vendors Discussions'
Board index < VintaSoft Twain < Hardware and Vendors Discussions
Ricoh image scanners.
Here is a list of Ricoh image scanners tested with our products by us or our customers:
  • Ricoh IS450
  • Ricoh Aficio MP161spf
  • Ricoh MP 4000
Ricoh image scanners are good image scanners and we can recommend them for usage with our products.
If you have tested other Ricoh image scanner with our product and want to share your experience, please post it here. Thank you in advance.
Re: Ricoh image scanners.
If you have Ricoh image scanner (for example Ricoh fi-8170) and you see "WIA-Not Friendly Name" device in the device list, you have "bad" Paperstream Twain driver for your Ricoh image scanner.
For using correct Paperstream Twain driver for your Ricoh image scanner please do the following steps:
  • Open the "Device Manager" in Windows settings and find the scanner under "Imaging Devices".
  • Right-click it and select "Disable device".
  • Right-click it again and select "Update driver".
  • Choose "Browse my computer for drivers > Let me pick from a list..."
  • Pick the specific model name (e.g., Ricoh fi-8170) instead of "USB Scanning Device."
  • Enable the device.
  • Reboot the PC and see the device list in your scanning application => The device list now contains "Paperstream" device instead of "WIA-Not Friendly Name" device.
