Announcements
Version 15.3 of VintaSoft Twain .NET SDK has been released.
What's new in this version:
  • .NET development
    • Added support for .NET 10.0 in Windows and Linux.
    • Created VintaSoft WIA .NET API that allows to work with WIA image scanners in Windows:
      • Enumerate WIA image scanners
      • Select WIA image scanner programmatically
      • Set any option of WIA image scanner (image type, image resolution, image position, etc)
      • Acquire black-white, grayscale or color images from WIA image scanner
      • Acquire the whole image or image region from WIA image scanner
      • Scan pages from the automatic document feeder (ADF) of WIA image scanner
      • Cancel image acquisition from WIA image scanner
      • Process scanned images
      • Get scanned image as Vintasoft.Imaging.VintasoftBitmap object
      • Save scanned images to a file
    • Demo applications:
      • Created the "WIA Image Scanning Console Demo" demo application that demonstrates how to acquire images from WIA image scanner in Windows.
  • Web development
    • Now VintaSoft Web TWAIN service (Windows and Linux edition) allows to work with TWAIN/WIA/SANE/eSCL image scanners:
      • Enumerate TWAIN/WIA/SANE/eSCL image scanners
      • Select TWAIN/WIA/SANE/eSCL image scanner programmatically
      • Set any capability/option of TWAIN/WIA/SANE/eSCL image scanner (image type, image resolution, image size, image position, page format, page orientation, image brightness, image contrast, etc)
      • Acquire black-white, grayscale or color images from TWAIN/WIA/SANE/eSCL image scanner
      • Acquire the whole image or image region from TWAIN/WIA/SANE/eSCL image scanner
      • Scan pages from the automatic document feeder (ADF) of TWAIN/WIA/SANE/eSCL image scanner
      • Cancel image acquisition from TWAIN/WIA/SANE/eSCL image scanner
      • Save scanned images to a file or upload to a server
    • Now Vintasoft TWAIN JavaScript API allows to work with TWAIN/WIA/eSCL image scanners in Windows and TWAIN/SANE/eSCL scanners in Linux.
      • Now all "VintaSoft Web TWAIN Scanning Demo" demo applications can work with TWAIN/WIA/SANE/eSCL image scanners.
Version 15.3.1.1 of VintaSoft Twain .NET SDK has been released.
  • .NET development
    • Improved the algorithm of SaneLocalDevice.AcquireImageSync method.
  • Web development
    • Improved the algorithm that returns information about capabilities/options, which are supported by WIA/SANE/eSCL device.
Version 15.3.2.1 of VintaSoft Twain .NET SDK has been released.
  • .NET development
    • Improved the algorithm that gets the host URL for eSCL device.
  • Web development
Version 15.3.3.1 of VintaSoft Twain .NET SDK has been released.
  • .NET development
    • Improved the algorithm, which acquires image from eSCL image scanner, for compatibility with Epson scanners.
    • Improved the algorithm of EsclDevice.AcquireImageSync method.
Version 15.3.4.1 of VintaSoft Twain .NET SDK has been released.
  • .NET development
    • Improved the algorithm, which acquires images from TWAIN device, for compatibility with TWAIN devices from "Yoshida Dental MFG" company.
Version 15.3.5.1 of VintaSoft Twain .NET SDK has been released.
  • .NET development
Version 15.3.7.1 of VintaSoft Twain .NET SDK has been released.
  • .NET development
    • Added new property WiaDevice.ScanThreshold and new method WiaDevice.GetSupportedScanThresholds.
    • Fixed the bugs in WiaDevice.ScanPageSize property and WiaDevice.GetSupportedScanPageSizes method.
    • Fixed the bug in EsclDevice.IsDuplexEnabled property.
Version 15.3.8.1 of VintaSoft Twain .NET SDK has been released.
  • .NET development
    • Improved the algorithm of JPEG decoder for compatibility with JPEG file that contains ICC profile.
Version 15.3.9.1 of VintaSoft Twain .NET SDK has been released.
  • .NET development
    • Improved the algorithm that acquires images from eSCL device.
    • Added the ability to work with eSCL device via SSL protocol if eSCL device uses a self-signed SSL certificate.
