Interleaved 25-code confounded with code-128
Post by BioT09 »
the Scanrectangle of the image contains Interleaved 25-codes and code-128. Before I decode I use the setting ScanBarcodeTypes = Vintasoft.Barcode.BarcodeType.Code128. Often the barcodereader reads not only the code-128, but also the interleaved 25-code with a strange value.
How can I avoid that?
Re: Interleaved 25-code confounded with code-128
Please send image with barcodes to support@vintasoft.com, we will analyze the image and give you recommendations.
Also you can try to set the BarcodeReader.Settings.MinConfidence property to 100.
Post by Yuri »
The problem seems to be solved in the latest modification of VintaSoftBarcode.NET SDK.
Please download the evaluation here: https://www.vintasoft.com/download.html and enjoy.
