Forum 'VintaSoft Twain ActiveX Discussions'
Board index < VintaSoft Twain < VintaSoft Twain ActiveX Discussions
Set scan area
Set scan area
Post by easyonex »
Hello.
I got the ActiveX a few days ago to update an older VB6 project with it.
So far everything works quite well. But I would like to be able to set the scan range, in millimeters!
Unfortunately it always stays in inches!?
    ' Einheit festlegen
    VSTwain1.Device_UnitOfMeasure = UNITOFMEASURE_Millimeters
    ' Scanbereich festlegen
    VSTwain1.Device_SetImageLayout 0, 0, 50, 110
Thank you for your answers.
Andreas
Re: Set scan area
Hello Andreas,
Our support team already answered to you question. I hope problem is solved.
Re: Set scan area
Post by easyonex »
Hello.
No, unfortunately not. I have set Device_PageSize property to 0 and also used Device_GetSupportedUnitsOfMeasure. However, the result remains the same. The unit remains in inches. I currently have the millimeters converted to inches until I solve the problem. See source code.
    ' disable application UI
    scanImagesButton.Enabled = False
    ' try to use TWAIN device manager 2.x
    VSTwain1.DeviceManager_IsTwain2Compatible = twain2CheckBox.Value
    ' if TWAIN device manager 2.x is not available
    If Not VSTwain1.DeviceManager_IsAvailable Then
        ' try to use TWAIN device manager 1.x
        VSTwain1.DeviceManager_IsTwain2Compatible = Not twain2CheckBox.Value
        ' if TWAIN device manager 1.x is not available
            MsgBox "TWAIN device manager is not available."
            ' enable application UI
            scanImagesButton.Enabled = True
            Exit Sub
    VSTwain1.Register "User", "Email", "Serial"
    ' open the device manager
    If Not VSTwain1.DeviceManager_Open() Then
        MsgBox VSTwain1.errorString
        Exit Sub
    ' if no devices are found in the system
    If VSTwain1.DeviceManager_DeviceCount = 0 Then
        MsgBox "Devices are not found."
        Exit Sub
    ' if device is NOT selected
    If Not VSTwain1.DeviceManager_ShowDefaultDeviceSelectionDialog() Then
        MsgBox "Device is not selected."
        Exit Sub
    ' select the device selected by user
    VSTwain1.DeviceManager_SelectedDeviceIndex = VSTwain1.DeviceManager_DefaultDeviceIndex
    If VSTwain1.Error Then
        Exit Sub
    ' open the device
    VSTwain1.Device_Open
        Exit Sub
    VSTwain1.Device_GetSupportedUnitsOfMeasure
    VSTwain1.Device_PageSize = 0
    ' set scan settings
    VSTwain1.Device_ShowUI = False ' showUiCheckBox.Value
    VSTwain1.Device_ShowIndicators = showIndicatorsCheckBox.Value
    VSTwain1.Device_DisableAfterAcquire = Not VSTwain1.Device_ShowUI
    VSTwain1.Device_TransferMode = TRANSFERMODE_Memory
    ' Scanbereich auslesen
    Dim nLeft As Single, nTop As Single, nRight As Single, nBottom As Single
    VSTwain1.Device_GetImageLayout nLeft, nTop, nRight, nBottom
    nLeft = 0
    nTop = 0
    nRight = 210
    nBottom = 297
    VSTwain1.Device_SetImageLayout nLeft, nTop, nRight, nBottom
    VSTwain1.Device_ImagePixelType = PIXELTYPE_Gray
    VSTwain1.Device_ImageBitDepth = 16
    ' acquire image(s) from the device
    Dim acquireModalState1 As ACQUIREMODALSTATE
    Do
      acquireModalState1 = VSTwain1.Device_AcquireImageModal
      Select Case acquireModalState1
        Case VSTwainLibCtl.ACQUIREMODALSTATE_ImageAcquired
          ' set a bitmap in the picture box
          Set Image1.Picture = VSTwain1.AcquiredImages_GetImage(0)
          imageCount = imageCount + 1
          totalImageCount = totalImageCount + 1
          ' dispose an acquired image
          VSTwain1.AcquiredImages_Clear
        Case VSTwainLibCtl.ACQUIREMODALSTATE_ScanCanceled
          MsgBox "Scan is canceled."
        Case VSTwainLibCtl.ACQUIREMODALSTATE_ScanFailed
          MsgBox "Scan is failed: " + VSTwain1.errorString
      End Select
    Loop While acquireModalState1 <> VSTwainLibCtl.ACQUIREMODALSTATE_None
    ' close the device
    VSTwain1.Device_Close
    ' close the device manager
    VSTwain1.DeviceManager_Close
The help is unfortunately not very helpful either, as it is written for .Net only and some functions (e.g. AddHandler) do not work in VB6.
I don't want to rewrite the old VB6 application completely, because it should only be extended by the scan function...
Furthermore, there are some other problems with the scanning.
The image when scanning in grayscale is displayed totally distorted and broken into stripes!? See screenshot.
https://share-your-photo.com/46e654ba50
Scanner : Brother MFC-2710DN
Re: Set scan area
Thank you for the code snippet.
How do you set unit of measure in your code? I cannot find line "VSTwain1.Device_UnitOfMeasure = UNITOFMEASURE.UNITOFMEASURE_Millimeters".
Please see example here: https://www.vintasoft.com/docs/vstwain/ ... ution.html
Re: Set scan area
Hello Andreas,
Have you solved the problem?
