- Loading algorithm of TIFF files has been improved.
- Ability to save TIFF with Zip compression is added.
- Memory usage in saving algorithm of TIFF files has been optimized.
- Ability to specify rendering settings for vector decoders is added.
- Ability to load PDF documents is added (VintaSoftPDF.NET Plug-in necessary).
- Ability to convert PDF documents to BMP, JPEG, GIF, PNG, TIFF, multipage TIFF files is added (VintaSoftPDF.NET Plug-in necessary).
- Ability to save images as PDF/A document is added (VintaSoftPDF.NET Plug-in necessary).
- Ability to decode and encode 1bpp JBIG2 standalone images or embedded into PDF document is added (VintaSoftJBIG2.NET Plug-in necessary).
- Ability to convert image file into 1 bpp JBIG2 file and back is added (VintaSoftJBIG2.NET Plug-in necessary).
- Thumbnail rendering speed has been increased.
- Ability to customize the behavior of visual tools is added.
- Ability to use advanced print settings (selection, current page, range of pages) is added.
- Decoders hierarchy is changed.
- Encoders hierarchy is changed.
- Bug in the thumbnail selection algorithm has been fixed.
- Image Viewer Demo, Annotation Demo, Image Converter Demo, Multipage TIFF Demo, Print Demo are updated.
- PDF Reader Demo, PDF Editor Demo, PDF Reader Web Demo and JBIG2 Codec Demo are created.
- Added ability to load/save annotations from/to PDF documents (VintaSoftPDF.NET Plug-in necessary).
- Bug in Pixel-to-Pixel preview mode of image with annotations and different horizontal and vertical resolution is fixed.
- New virtual method (SetResolution) is added to AnnotationBase Class.
- New method (CalculateLength) is added to IRuler interface.
- Added ability to build symmetrical annotations visually.
- Some major and minor fixes.
- Annotation Demo has been updated.
- View and print PDF documents version 1.0-1.7.
- Render PDF files to any supported raster image format.
- Display PDF file's bookmarks and any page annotations.
- Create and save PDF documents version 1.0-1.7 and image-only PDF/A.
- Pack and optimize PDF file content.
- Create and edit PDF file bookmarks.
- Work with PDF page annotations using features of VintaSoftAnnotation.NET Plug-in.
- Supported fonts: TrueType, Type0, Type1, Type3.
- Supported compressions: CCITT3, CCITT4, JPEG, LZW, Run Length, Zip, JBIG2.
- Supported color spaces: DeviceGray, DeviceRGB, DeviceCMYK, Indexed, Separation, Pattern.
- PDF Reader Demo, PDF Editor Demo, PDF Drawing Demo and Web PDF Reader Demo are created.
- Decode and encode 1bpp standalone and embedded into PDF file JBIG2 images.
- Convert any supported image format to JBIG2 and back.
- Work with multipage JBIG2 file supported: create, manipulate pages, merge, split.
- Arithmetic decoding and encoding supported.
- MMR decoding and encoding supported.
- Huffman table decoding (standard and user-supplied) supported.
- Lossless or Lossy compression supported.
- Opportunity to use symbol dictionary for more effective compression.
- JBIG2 Demo is created.
