Save Multi-images PDF as stream into SQlserver
Post by chen_jon »
I used the following code to save multi-page images as PDF into table. But it only saves the last image:
bool firstImage=true;
System.IO.MemoryStream mem=null;
while (m_TwainObject.AcquireModal())
if (firstImage)
mem = m_TwainObject.GetImageAsStream(0, ImageFileFormat.PDF);
firstImage = false;
m_TwainObject.SaveImage(0, mem, ImageFileFormat.PDF);
catch (Exception ex)
MessageBox.Show(ex.Message);
//code below to save into table
//dbService.SaveScannedImage(mem.ToArray());
My question: Can the current library save multi-image PDF? If yes, how?
Thanks for help
Re: Save Multi-images PDF as stream into SQlserver
Hello Chen,
Thank you for your message, your code is fully correct. We have found a bug in the SaveImage(int, Stream, ImageFileFormat) method in version 4.3.0.1 of library and now this bug is fixed. Please download the latest version (4.3.0.3) version of library from this page: https://www.vintasoft.com/download.html
