Do you need to store each image as a single PDF document or store all images as a multipage PDF document?
Current version of library allows to save only the single image to the stream using the GetImageAsStream method. We will add ability to add image to an existing PDF document stored in the stream in next version of library.
Each image is a separate document. They are scanning membership cards. So they look up the member's record and on the member form is a button for scanning documents, they click the scan button, I read the image into memory and then I want to save it to a table called memberdocuments along with the Social Security number of the member. The pdf will be stored I am assuming in a image or a binary field. Later on I can retrieve the pdf record and display it in a pop up window to the user.
I don't mean the code to save the file in the table but the part where I acquire the image from the scanner and convert it to the type to save to an image field in the table.
