using System.Drawing;
using System.Security.Cryptography.X509Certificates;
using Vintasoft.Imaging.Pdf;
/// Adds digital signature with image appearance to a PDF page.
public class PdfPageDigitalSignatureHelper_ImageAppearance
public static void Run()
// get the X509 certificate from .pfx-file
using (X509Certificate2 certificate = new X509Certificate2("TestCertificate.pfx", "test"))
// create a helper that alows to add digital signature to a PDF document
PdfPageDigitalSignatureHelper digitalSignatureHelper =
new PdfPageDigitalSignatureHelper(certificate, new RectangleF(20, 20, 250, 100));
// set signature information
digitalSignatureHelper.SignerName = "Mr. X";
digitalSignatureHelper.SigningReason = "Approval";
digitalSignatureHelper.SigningLocation = "My Location";
digitalSignatureHelper.SignerContactInfo = "Phone: 9999-123-45-67";
// set the name of image file that defines the signature appearance
digitalSignatureHelper.SignatureImageFilename = "SignatureImage.svg";
// add digital signature to the first PDF page, sign PDF document and save PDF document to the output file
digitalSignatureHelper.SignDocument("TestDocumentToSign.pdf", "TestDocumentToSign-signed.pdf", 0);
Forum 'Code samples'
Code samples for VintaSoft PDF .NET Plug-in. Here you can request a code sample.
Board index < VintaSoft Imaging < VintaSoft PDF .NET Plug-in Discussions < Code samples
