Here is C# code that demonstrates how to add digital signature with timestamp to a PDF document:
using System.Drawing;
using System.Security.Cryptography.X509Certificates;
using Vintasoft.Imaging.Pdf;
/// Adds digital signature with timestamp to a PDF page.
public class PdfPageDigitalSignatureHelper_Timestamp
    public static void Run()
        // get the X509 certificate from .pfx-file
        using (X509Certificate2 certificate = new X509Certificate2("TestCertificate.pfx", "test"))
            // create a helper that alows to add digital signature to a PDF document
            PdfPageDigitalSignatureHelper digitalSignatureHelper =
                new PdfPageDigitalSignatureHelper(certificate, new RectangleF(20, 20, 250, 100));
            // set the reason for signing
            digitalSignatureHelper.SigningReason = "Approve document";
            // set the name of image file that defines the signature appearance
            digitalSignatureHelper.SignatureImageFilename = "SignatureImage.svg";
            // set the URL to the timestamp server
            digitalSignatureHelper.TimestampServerUrl = "http://timestamp.comodoca.com/";
            // add digital signature to the first PDF page, sign PDF document and save PDF document to the output file
            digitalSignatureHelper.SignDocument("TestDocumentToSign.pdf", "TestDocumentToSign-signed.pdf", 0);
