Announcements
Version 15.1 of VintaSoft Imaging .NET SDK has been released.
The new version 15.1 of VintaSoft Imaging .NET SDK and Plug-ins has been released!
What's new in VintaSoft Imaging .NET SDK 15.1:
  • .NET development
    • Image codecs:
      • Created the decoder for CAD (DXF, DWG) files.
        • Render CAD document.
        • Print CAD document in vector and raster form.
        • Convert CAD document to a vector PDF or PDF/A document with text, links and navigation.
        • Convert CAD document to SVG document with text.
        • Convert CAD document to any image format supported by VintaSoft Imaging .NET SDK.
        • Search and extract text.
    • Fixed several minor bugs.
What's new in VintaSoft Office .NET Plug-in 7.1:
  • Added the support for PPTX documents:
    • Render PPTX document.
    • Render charts in PPTX documents.
    • View PPTX document in WinForms, WPF, WEB.
    • Print PPTX document in vector and raster form.
    • Convert PPTX document to a vector PDF or PDF/A document with text, links and navigation.
    • Convert PPTX document to SVG document with text.
    • Convert PPTX document to any image format supported by VintaSoft Imaging .NET SDK.
    • Search and extract text from PPTX document.
    • Use mouse for selecting text in PPTX document in image viewer.
    • Use keyboard for selecting and navigating text in PPTX document in image viewer.
  • Added the ability to render SmartArt-objects in DOCX, XLSX, PPTX document.
  • Improved the chart rendering in DOCX, XLSX document.
  • Improved the rendering of DOCX and XLSX documents.
What's new in VintaSoft PDF .NET Plug-in 12.1:
  • .NET development
    • Added the ability to set the Unicode-table for PDF font (PdfFont.SetUnicodeMapping method).
    • The PdfFontViewerControl UI-control now can display the Unicode character information for PDF font characters and can set the Unicode character for a PDF font character.
    • Added the ability to vectorize only the text content in PDF document (PdfFlattenTextCommand class).
    • Created the helper-class PdfPageDigitalSignatureHelper that simplifies the PDF document signing process with a digital signature.
    • Demo applications:
      • PdfEditorDemo: Added the ability to restore the text encoding of font in PDF document.
What's new in VintaSoft Annotation .NET Plug-in 15.1:
  • .NET development
    • All WinForms and WPF rectangle-based annotations now can display text.
    • All WinForms and WPF line-based annotations now can display text.
  • Web development
    • All web rectangle-based annotations now can display text.
    • All web line-based annotations now can display text.
    • Now web text annotations can adjust their size to the text size (WebTextAnnotationViewJS.AutoSize property).
What's new in VintaSoft OCR .NET Plug-in 9.1:
  • .NET development
    • The used Tesseract OCR engine has been updated to version 5.5.2.
Version 15.1.1.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Now Vintasoft.Imaging.Drawing.SkiaSharp assembly uses SkiaSharp 3.119.4.
    • Now the StreamDataStorage class allows to override public methods.
  • Web development
    • Created the VintasoftWebServiceGlobalSettings class that allows to set the global settings for VintaSoft Imaging web services.
    • Fixed the bugs in WebPropertyGridJS class.
    • Now the VintaSoft JavaScript files (evaluation version) are available using npm-packages on web site https://www.npmjs.com.
  • Web development
    • Created the WebInteractionControllerBaseJS class that is a base class for builders/transformers of interactive objects.
    • The builder for rectangular annotation (WebRectangularObjectBuilderJS class) is made public.
    • The transformer for rectangular annotation (WebRectangularObjectTransformerJS class) is made public.
    • Now WebAnnotationViewJS class have properties, which allow to access the builder/transformer of annotation.
    • Source code of WebTriangleAnnotationViewJS class is made public and added to the AnnotationDemo project. Source code shows how to create new annotation type that is derived from an existing annotation type.
    • Source code of WebMarkAnnotationViewJS class is made public and added to the AnnotationDemo project. Source code shows how to create new annotation type from scratch.
  • .NET development
    • Added the ability to interact with PPTX document: links, navigation between slides, application run, document opening.
    • Added the ability to automatically calculate the column width in XLSX document when converting a CSV/TSV file to an XLSX file.
  • Web development
Version 15.1.2.1 of VintaSoft Imaging .NET SDK has been released.
  • .NET development
    • Improved the algorithm of Vintasoft.Imaging.ImageProcessing.Document.BorderRemovalCommand class.
  • .NET development
    • Fixed the bug in algorithm that calculates the bottom indent for a text block in PPTX document.
