Version 16.0 of VintaSoft Barcode .NET SDK has been released.
What's new in this version:
.NET development
Added the ability to detect regions of 2D barcodes (Aztec, DataMatrix, QR Code, HanXinCode, MaxiCode) in an image using neural network (AI). Usage of a neural network (AI) provides a significant increase in the performance of barcode recognition on medium and large-sized images.
Added the ability to detect regions of 1D barcodes in an image using neural network (AI). Usage of a neural network (AI) provides a significant increase in the performance of barcode recognition on medium and large-sized images.
Added the ability to recognize and generate DMRE barcodes (Data Matrix Rectangular Extension).
Added the ability to recognize IATA barcodes (IATA BCBP Aztec, IATA BCBP DataMatrix, IATA BCBP PDF417, IATA BCBP QR).
The 2D barcode print quality test has been updated to the "ISO/IEC 15415 Third edition (2024-12)" specification.
The 1D barcode print quality test has been updated to the "ISO/IEC 15416 Third edition (2025-01)" specification.
The 1D barcode print quality test now returns information about quiet zone around barcode: ISO15416ScanReflectanceProfile.QuietZoneLeft, ISO15416ScanReflectanceProfile.QuietZoneRight.
Improved the algorithm that recognizes QR Code barcodes with print defect.
Added the ability to specify barcode layout zones on an image (Vintasoft.Barcode.BarcodeLayoutInfo), which can significantly increase performance of the barcode recognition process.
Added the ability to simultaneously recognize barcodes with non-inverted and inverted colors.
Version 16.0.1.1 of VintaSoft Barcode .NET SDK has been released.
.NET development
Improved the quality of barcode recognition if barcode recognition is executed in automatic barcode recognition mode and barcodes regions are recognized using neural networks.
Increased the barcode recognition speed up to 20% for barcode recognition on color images.
Increased the barcode recognition speed if only 1 barcode is expected and a barcode region is recognized using neural network.
Version 16.0.2.1 of VintaSoft Barcode .NET SDK has been released.
.NET development
Improved the barcode recognition quality if the automatic barcode recognition mode is used and barcode regions are detected using AI.
Significantly increased the barcode recognition performance if barcodes are recognized in a large grayscale image, the image is decoded using GDI drawing engine, AI is used for detection of barcode regions.
Improved the algorithm that stops barcode recognition (ReaderSettings.RecognitionTimeout) when barcode regions are detected using AI.
Improved the algorithm that recognizes DataMatrix barcode with damaged L-pattern.
Fixed the bug in the barcode recognition algorithm that occurred when barcode regions should have been detected using AI, but the barcode recognizer did not use AI because the use of AI was not optimal.
Fixed the bug in algorithm that calculates grade of FixedPatternDamage.AG parameter for DataMatrix barcode in the ISO 15415 barcode print quality test.
Version 16.0.3.1 of VintaSoft Barcode .NET SDK has been released.
.NET development
Fixed the bug in algorithm that calculates the 'FixedPatternDamage.ClockAndSolidArea' grade for DataMatrix barcode in ISO 15415 barcode print quality test.
Version 16.0.4.1 of VintaSoft Barcode .NET SDK has been released.
