Announcements
Version 15.2 of VintaSoft Barcode .NET SDK has been released.
What's new in this version:
  • Added the ability to recognize and generate GS1 Digital Link QR barcodes.
  • Added the ability to recognize and generate GS1 Digital Link DataMatrix barcodes.
  • Added the support for "GS1 Digital Link" standard.
  • Updated the GS1 Application Identifiers list to the specification 25.0 from 2025 year.
  • Added the ability to generate the structure of barcode in vector form.
  • Significantly increased the performance of sequential barcode recognition in low-quality images obtained from one source (BarcodeReader.Settings.SerialRecognition property).
  • Increased the performance of barcode recognition when barcodes are recognizing sequentially in automatic or iterative mode.
Version 15.2.1.1 of VintaSoft Barcode .NET SDK has been released.
  • Improved the algorithm that searches the region of 1D barcode.
Version 15.2.2.1 of VintaSoft Barcode .NET SDK has been released.
  • Added the ReaderSettings.DataMatrixLPatternMinQuietZone property, which allows to specify the size of the quiet zone, in percents, around the L-pattern of the DataMatrix barcode. This property should be used only if the size of the quiet zone around the DataMatrix barcode is less than the minimum size defined by the DataMatrix barcode specification.
Version 15.2.3.1 of VintaSoft Barcode .NET SDK has been released.
  • Fixed the bug in algorithm that calculates values of ISO15415.ModulationGrade and ISO15415.FixedPatternDamage properties in ISO15415 barcode print quality test for QR barcodes.
Version 15.2.4.1 of VintaSoft Barcode .NET SDK has been released.
  • Now Vintasoft.Barcode.SkiaSharp assembly uses SkiaSharp 3.119.0.
  • Fixed the bug in algorithm that calculates quality of fixed elements for QR barcode in ISO15415 barcode print quality test.
Version 15.2.5.1 of VintaSoft Barcode .NET SDK has been released.
  • Fixed the bug in the ISO15415 barcode print quality test that could occur when assessing the quality of fixed elements in some QR barcodes.
Version 15.2.6.1 of VintaSoft Barcode .NET SDK has been released.
  • Improved the algorithm that filters erroneously recognized EAN barcodes.
Version 15.2.7.1 of VintaSoft Barcode .NET SDK has been released.
  • Fixed the big in algorithm that calculates one of the properties of the average scan profile in the ISO15416 barcode print quality test.
  • Fixed the bug in algorithm that calculates the Decodability value for EAN barcodes in the ISO15416 barcode print quality test.
Version 15.2.8.1 of VintaSoft Barcode .NET SDK has been released.
  • Improved the algorithm that calculates value of "Decodability" parameter in ISO15416 barcode print quality test for EAN barcode.
  • Increased the performance of ISO15415 barcode print quality test.
Version 15.2.9.1 of VintaSoft Barcode .NET SDK has been released.
  • Now Barcode assemblies use Vintasoft.Shared assembly 4.6.
