Code samples
Board index < VintaSoft Imaging < VintaSoft Imaging .NET SDK and Plug-ins Discussions < Code samples
function __searchText() {
var imageIndex = 0;
// get image viewer that is associated with web document viewer
var imageViewer = _docViewer.get_ImageViewer();
// get image collection that is associated with image viewer
var images = imageViewer.get_Images();
// get image
var image = images.getImage(imageIndex);
// get image metadata
var imageMetadata = image.get_Metadata();
// request text region of image
imageMetadata.requestTextRegion(
function (data) {
// get text region of image
var imageTextRegion = data.textRegion;
// create regular expresion for text search
var regExp = new RegExp("SDK", "gi");
// search text "SDK" on image
var searchedTextRegions = imageTextRegion.searchText(regExp, "CurrentPage");
// for each search result
for (var i = 0; i < searchedTextRegions.length; i++) {
// scroll to the text region in image viewer
__scrollToTextRegion(imageViewer, image, searchedTextRegions[i].region);
function (data) {
alert("Error requesting text region.");
function __scrollToTextRegion(imageViewer, image, region) {
var selectedRegions = region.get_SelectionRegions();
var leftTopPoint = selectedRegions[0][0];
var rightBottomPoint = selectedRegions[0][2];
// get the center point, in text region space, of text region
var centerPoint = { x: (leftTopPoint.x + rightBottomPoint.x) / 2, y: (leftTopPoint.y + rightBottomPoint.y) / 2 };
// get transform from text space to the image space
var transform = region.getTransformFromTextToImageSpace(image.get_Resolution());
// transform point from the text space to the image space
var pointInImageSpace = transform.transformPoint(centerPoint);
// scroll to the text region on image in image viewer
imageViewer.scrollToImagePoint(pointInImageSpace.x, pointInImageSpace.y);
// get TextSelectionTool used in web document viewer
var textSelectionTool = _docViewer.getVisualToolById("TextSelectionTool");
// select text on image using the TextSelectionTool
textSelectionTool.set_SelectedRegion(region);
