namespace ConsoleApp1
internal class Program
// specify that GDI+ must be used as drawing engine
Vintasoft.Barcode.GdiAssembly.Init();
// an array of Application Identifiers, which should be used in GS-128 barcode
Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue[] aiValues = new Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue[2];
// create first Application Identifier
Vintasoft.Barcode.GS1.GS1ApplicationIdentifier ai = Vintasoft.Barcode.GS1.GS1ApplicationIdentifiers.FindApplicationIdentifier("02");
aiValues[0] = new Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(ai, "40529176710608");
// create second Application Identifier
ai = Vintasoft.Barcode.GS1.GS1ApplicationIdentifiers.FindApplicationIdentifier("400");
aiValues[1] = new Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(ai, "WICAV240308BCN1");
// create printable value of GS-128 barcode
System.Text.StringBuilder printableValue = new System.Text.StringBuilder();
foreach (Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue value in aiValues)
printableValue.Append(value);
// create barcode writer
using (Vintasoft.Barcode.BarcodeWriter writer = new Vintasoft.Barcode.BarcodeWriter())
// specify that barcode writer must create 24-bpp barcode image
writer.Settings.PixelFormat = Vintasoft.Barcode.BarcodeImagePixelFormat.Bgr24;
// specify that barcode writer must generate GS-128 barcode
writer.Settings.Barcode = Vintasoft.Barcode.BarcodeType.Code128;
writer.Settings.Value = Vintasoft.Barcode.GS1.GS1Codec.GS1_128.Encode(aiValues, writer.Settings);
// specify that barcode writer must add barcode text under barcode image
writer.Settings.ValueVisible = true;
writer.Settings.UseLegacyVectorGenerator = false;
writer.Settings.PrintableValue = printableValue.ToString();
// generate image (with specified size) of GS-128 barcode
Vintasoft.Imaging.VintasoftBitmap barcodeImage = writer.GetBarcodeAsVintasoftBitmap(491, 80, Vintasoft.Barcode.UnitOfMeasure.Pixels);
// save generated image to a file
Vintasoft.Barcode.ImageCodecs.Default.Encode(barcodeImage, "GS128BarcodeImage.png");
Here is VB.NET example that demonstrates how to generate GS-128 barcode image using VintaSoft Barcode .NET SDK:
Module Module1
Sub Main()
' specify that GDI+ must be used as drawing engine
' an array of Application Identifiers, which should be used in GS-128 barcode
Dim aiValues As Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue() = New Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(1) {}
' create first Application Identifier
Dim ai As Vintasoft.Barcode.GS1.GS1ApplicationIdentifier = Vintasoft.Barcode.GS1.GS1ApplicationIdentifiers.FindApplicationIdentifier("02")
aiValues(0) = New Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(ai, "40529176710608")
' create second Application Identifier
aiValues(1) = New Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue(ai, "WICAV240308BCN1")
' create printable value of GS-128 barcode
Dim printableValue As New System.Text.StringBuilder()
For Each value As Vintasoft.Barcode.GS1.GS1ApplicationIdentifierValue In aiValues
Next
' create barcode writer
Using writer As New Vintasoft.Barcode.BarcodeWriter()
' specify that barcode writer must create 24-bpp barcode image
' specify that barcode writer must generate GS-128 barcode
' specify that barcode writer must add barcode text under barcode image
writer.Settings.ValueVisible = True
writer.Settings.UseLegacyVectorGenerator = False
' generate image (with specified size) of GS-128 barcode
Dim barcodeImage As Vintasoft.Imaging.VintasoftBitmap = writer.GetBarcodeAsVintasoftBitmap(491, 80, Vintasoft.Barcode.UnitOfMeasure.Pixels)
' save generated image to a file
Vintasoft.Barcode.ImageCodecs.[Default].Encode(barcodeImage, "GS128BarcodeImage.png")
End Using
End Sub
End Module
