Array of multiple images send mutiple request for DeserializeAnnotationCollection
Post by jwalit.katira »
In ASP.NET Core API When we are trying to open multiple file using array of jpg using openfile() Method , it send multiple request for DeserializeAnnotationCollection method even though only one image is display on document viewer.
Can you please share your input
Jwalit Katira
Re: Array of multiple images send mutiple request for DeserializeAnnotationCollection
Hello Jwalit,
If you are using WebAnnotationVieweJS control, the control gets information about annotations for each image loaded in viewer.
We are using documentviewer and imageviewer below is the code how we call from JS
 let images = [
      "0.jpg",
      "1.jpg",
      "2.jpg",
      "3.jpg",
      "4.jpg",
      "5.jpg",
imageViewer = docViewer.get_ImageViewer();
imageViewer.get_Images().openFiles(images);
and even if its annotation viewer why do control gets information about annotations for each image when only first image is rendering
Let me know if this behavior can be changed
Jwalit Katira
Hello Jwalit,
Yes, WebAnnotationViewerJS control loads all annotations for all images in viewer when images are added to the viewer. We will improve this algorithm in the future.
Post by chintan.shah »
In which version or by which date we get fix for this issue?
Hello Jwalit,
This performance problem is not critical and has effect only if many images are loaded in viewer. We will notify you when problem is fixed. Now I cannot give you the exact date.
