Code samples
Board index < VintaSoft Imaging < VintaSoft Imaging .NET SDK and Plug-ins Discussions < Code samples
/// Saves the TIFF file with specified ICC profile.
/// <param name="sourceFilePath">The path to a source TIFF file.</param>
/// <param name="iccProfilePath">The path to an ICC profile that should be applied to the source TIFF file.</param>
/// <param name="outputFilePath">The path to an output TIFF file.</param>
private static void Save(string sourceFilePath, string iccProfilePath, string outputFilePath)
// open TIFF file
using (Vintasoft.Imaging.Codecs.ImageFiles.Tiff.TiffFile tiffFile = new Vintasoft.Imaging.Codecs.ImageFiles.Tiff.TiffFile(sourceFilePath))
// create decoding settings
Vintasoft.Imaging.Codecs.Decoders.DecodingSettings decodingSettings = new Vintasoft.Imaging.Codecs.Decoders.DecodingSettings();
// enable color management
decodingSettings.ColorManagement = new Vintasoft.Imaging.ColorManagement.ColorManagementDecodeSettings();
// use embedded ICC profile
decodingSettings.ColorManagement.UseEmbeddedInputProfile = true;
// get image of TIFF page
using (Vintasoft.Imaging.VintasoftImage image = tiffFile.Pages[0].GetImage(decodingSettings, null))
// load ICC profile data
byte[] iccProfileData = System.IO.File.ReadAllBytes(iccProfilePath);
// create ICC profile data
using (Vintasoft.Imaging.ColorManagement.Icc.IccProfile profile = new Vintasoft.Imaging.ColorManagement.Icc.IccProfile(iccProfileData))
// create color transform command
Vintasoft.Imaging.ImageProcessing.Color.ColorTransformCommand command = CreateCommand(image, profile);
// transform image
command.ExecuteInPlace(image);
// create TIFF file
using (Vintasoft.Imaging.Codecs.ImageFiles.Tiff.TiffFile newTiffFile = CreateTiffFile(image, iccProfileData))
// save TIFF file
newTiffFile.Save(outputFilePath);
/// Creates <see cref="Vintasoft.Imaging.ImageProcessing.Color.ColorTransformCommand"/>.
/// <param name="sourceImage">The source image.</param>
/// <param name="iccProfile">The ICC profile.</param>
/// <returns>
/// The <see cref="Vintasoft.Imaging.ImageProcessing.Color.ColorTransformCommand"/>.
/// </returns>
private static Vintasoft.Imaging.ImageProcessing.Color.ColorTransformCommand CreateCommand(Vintasoft.Imaging.VintasoftImage sourceImage, Vintasoft.Imaging.ColorManagement.Icc.IccProfile iccProfile)
// create command
Vintasoft.Imaging.ImageProcessing.Color.ColorTransformCommand command = new Vintasoft.Imaging.ImageProcessing.Color.ColorTransformCommand();
// create decode settings
Vintasoft.Imaging.ColorManagement.ColorManagementDecodeSettings decodeSettings = new Vintasoft.Imaging.ColorManagement.ColorManagementDecodeSettings();
// set the ICC profile
switch (iccProfile.DeviceColorSpace)
case Vintasoft.Imaging.ColorSpaceType.CMYK:
decodeSettings.OutputCmykProfile = iccProfile;
break;
case Vintasoft.Imaging.ColorSpaceType.sRGB:
decodeSettings.OutputRgbProfile = iccProfile;
break;
case Vintasoft.Imaging.ColorSpaceType.Gray:
decodeSettings.OutputGrayscaleProfile = iccProfile;
break;
default:
throw new System.NotImplementedException();
// set the color transform
command.ColorTransform = decodeSettings.ColorSpaceTransforms.GetColorTransform(
sourceImage.ColorSpaceFormat, sourceImage.ColorSpaceFormat);
return command;
/// Creates the TIFF file.
/// <param name="image">The image.</param>
/// <param name="iccProfileData">The ICC profile data.</param>
/// <returns>
/// The TIFF file.
/// </returns>
private static Vintasoft.Imaging.Codecs.ImageFiles.Tiff.TiffFile CreateTiffFile(Vintasoft.Imaging.VintasoftImage image, byte[] iccProfileData)
// create TIFF file
Vintasoft.Imaging.Codecs.ImageFiles.Tiff.TiffFile tiffFile = new Vintasoft.Imaging.Codecs.ImageFiles.Tiff.TiffFile();
// add image
tiffFile.Pages.Add(image);
// get IFD tags
Vintasoft.Imaging.Codecs.ImageFiles.Tiff.TiffTagCollection ifdTags = tiffFile.Pages[tiffFile.Pages.Count - 1].IFD.Tags;
// add ICC profile tag
ifdTags.Add(Vintasoft.Imaging.Codecs.ImageFiles.Tiff.TiffTagId.ICCProfile, iccProfileData);
return tiffFile;
