What's new in this version:
- .NET development
- Added support for .NET 7 in Windows, Linux and macOS.
- Refactored the SDK architecture:
- Vintasoft.Barcode.dll assembly does not depend from System.Drawing library anymore and can be used in Windows, Linux and macOS.
- Vintasoft.Barcode.dll assembly now depends on Vintasoft.Shared.dll assembly.
- Now Vintasoft.Barcode.dll assembly uses Vintasoft.Imaging.VintasoftBitmap class (from Vintasoft.Shared.dll assembly) for working with bitmap - this allows to get/transfer bitmap from/to VintaSoft Imaging .NET SDK without memory duplication.
- Created Vintasoft.Barcode.Gdi.dll assembly - an extension, which allows to work with barcodes using System.Drawing library in Windows.
- Created Vintasoft.Barcode.Wpf.dll assembly - an extension, which allows to work with barcodes in WPF.
- Created Vintasoft.Barcode.SkiaSharp.dll assembly - an extension, which allows to work with barcodes using SkiaSharp library (.NET library with unmanaged code) in Windows, Linux, macOS.
- Created Vintasoft.Barcode.ImageSharp.dll assembly - extension, which allows to work with barcodes using SixLabors.ImageSharp library (fully managed .NET library) in Windows, Linux, macOS.
- Discontinued the support of Vintasoft.WpfBarcode.dll assembly. Use Vintasoft.Barcode.dll and Vintasoft.Barcode.Wpf.dll assemblies instead of Vintasoft.WpfBarcode.dll assembly.
- The functionality matrix of .NET assemblies can be seen in documentation: https://www.vintasoft.com/docs/vsbarcod ... atrix.html
- Information about API changes can be read in documentation: https://www.vintasoft.com/docs/vsbarcod ... v14_0.html
- Added the ability to use adaptive binarization for barcode recognition (see ReaderSettings.AdaptiveBinarizationStep property).
- Improved the algorithm that recognizes barcodes in automatic mode.
- Web development
- Added support for .NET 7.0 rc1 in Windows, Linux and macOS.
- Vintasoft.Barcode.Web.Services.dll assembly does not depend on System.Drawing library anymore and can be used in Windows, Linux and macOS.
- Xamarin development
- Discontinued support for Xamarin.Android platform.
