namespace ConsoleApp1
class Program
// open file stream
using (System.IO.FileStream fs = new System.IO.FileStream("multipage.tif", System.IO.FileMode.Open, System.IO.FileAccess.ReadWrite))
// create image collection
using (Vintasoft.Imaging.ImageCollection images = new Vintasoft.Imaging.ImageCollection())
// add images from file stream to the image collection
images.Add(fs);
// for each image in image collection
for (int i = 0; i < images.Count; i++)
// change image resolution
images[i].Resolution = new Vintasoft.Imaging.Resolution(200, 200);
// create TIFF encoder
Vintasoft.Imaging.Codecs.Encoders.TiffEncoder encoder = new Vintasoft.Imaging.Codecs.Encoders.TiffEncoder();
// specify that TIFF encoder must save image collection to the source file and switch image collection to the saved file
encoder.SaveAndSwitchSource = true;
// save image collection to the source TIFF file
images.SaveSync(fs, encoder);
Forum 'Code samples'
Board index < VintaSoft Imaging < VintaSoft Imaging .NET SDK and Plug-ins Discussions < Code samples
