JBIG2, JPEG2000, Document Cleanup, OCR, DICOM, Forms Processing and Office Plug-ins.
What's new in VintaSoft Imaging .NET SDK 10.0:
- .NET development
- Supported platforms:
- Added the support for .NET 5 for Windows.
- Improved the algorithm that extracts thumbnail of TIFF image from EXIF metadata.
- Demo applications:
- Added new functionality to ImagingDemo/WpfImagingDemo:
- Added the ability to binarize image using color gradient.
- Added the ability to replace color in image using color gradient.
- Web development
- Added the support for TypeScript.
- Added support for Angular.
- Discontinued support of ASP.NET MVC4 because this is legacy technology and Microsoft discontinued support of ASP.NET MVC 4 starting from July 1st, 2019 - https://dotnet.microsoft.com/platform/s ... icy/aspnet
- Discontinued support of WCF because this is legacy technology.
- Added many minor improvements in JavaScript engine.
- Added the ability to rotate single image in web image viewer.
- Fixed not critical bugs in JavaScript engine.
- Created tutorials, which describe how to view images and documents in ASP.NET Core with Angular, ASP.NET Core with React, ASP.NET Core with React and Redux, ASP.NET Core, ASP.NET MVC5, ASP.NET WebForms.
- Created demo applications for ASP.NET Core with Angular:
- AspNetCoreAngularAnnotationDemo - demonstrates how to view and annotate images and documents in ASP.NET Core with Angular.
- AspNetCoreAngularBarcodeAdvancedDemo - demonstrates how to recognize 1D/2D barcodes in images and how to generate barcode images in ASP.NET Core with Angular.
- AspNetCoreAngularCameraDemo - demonstrates how to capture images from DirectX camera in ASP.NET Core with Angular. Demo application also allows to view/process/annotate captured images, recognize barcodes from captured images, save captured images.
- AspNetCoreAngularImagingDemo - demonstrates how to view and process images and documents in ASP.NET Core with Angular.
- AspNetCoreAngularPdfReaderDemo - demonstrates how to view PDF documents with ability to navigate bookmarks, view page thumbnails, search text, extract image-resources in ASP.NET Core with Angular.
- AspNetCoreAngularTwainScanningAdvancedDemo - demonstrates how to acquire images from TWAIN scanner inASP.NET Core with Angular. Demo application also allows to view/process/annotate scanned images, recognize barcodes in scanned images, save scanned images.
What's new in VintaSoft Office .NET Plug-in 2.0:
- .NET development
- Added support of XLSX documents
- Render XLSX documents.
- View XLSX document in WinForms, WPF, WEB.
- Print XLSX documents in vector and raster form.
- Overlay XLSX page over PDF page in vector form and with text.
- Convert XLSX document to a vector PDF or PDF/A document with text, links and navigation.
- Convert XLSX document to SVG document with text.
- Convert XLSX document to any image format supported by VintaSoft Imaging .NET SDK.
- Search and extract text from XLSX document.
- Use mouse for selecting text in XLSX document in image viewer.
- Use keyboard for selecting and navigating text in XLSX document in image viewer.
- Navigate links in XLSX document in image viewer.
- Ability to specify alignment settings of XLSX document: page size, size padding, zoom for page content.
- Improved support of DOCX documents
- Added support for floating tables and images.
- Added support for text flow around floating elements.
- Added support for gradient fills.
- Added support for alignment and paddings in lists.
- Added the ability to specify alignment settings of XLSX document: page size, size padding, zoom for page content.
- Increased performance of algorithm that renders DOCX documents.
- Increased performance of algorithm that renders thumbnails of DOCX pages.
- Improved quality of rendered DOCX pages.
- Improved the algorithm that converts DOCX to PDF, SVG.
- Web development
What's new in VintaSoft PDF .NET Plug-in 7.0:
- .NET development
- Added the ability to add extended properties for digital signature.
- Increased performance of algorithm that parses PDF document.
What's new in VintaSoft Document Cleanup .NET Plug-in 5.0:
- .NET development
- Improved the algorithm of AdvancedReplaceColorCommand class:
- Added the ability to replace color that is not fall in the color spheres.
What's new in VintaSoft Annotation .NET Plug-in 10.0:
- .NET development
What's new in VintaSoft JBIG2 .NET Plug-in 7.0:
- .NET development
What's new in VintaSoft JPEG2000 .NET Plug-in 6.0:
- .NET development
What's new in VintaSoft OCR .NET Plug-in 5.0:
- .NET development
What's new in VintaSoft DICOM .NET Plug-in 3.0:
- .NET development
What's new in VintaSoft Forms Processing .NET Plug-in 3.0:
- .NET development
