Comment Annotation disappears when multi-selecting in edit mode.
Post by IntegraHarlan »
If i try to select more than one comment annotations in edit mode, the previously selected comment disappears.
I am able to reproduce this in the Winforms PdfEditorDemo applications.
Steps:
  • Open a pdf file in the demo app.
  • Add two comment annotations.
  • Select Edit interaction mode.
  • Click on the Pdf document so that no annotations are selected.
  • Select the first comment annotation.
  • Press the CTRL key.
  • Select the second comment annotation.
You will see that the first selected comment annotations disappears from the document.
Is this something that can be corrected?
Harlan.
Re: Comment Annotation disappears when multi-selecting in edit mode.
Hi Harlan,
Thank you for information.
In version 9.1.0.17 we haveВ fixed the bug, which occurs during selection of several PDF-comments in image viewer when PdfAnnotationTool is working in Edit mode, and now the problem is solved. Please use version 9.1.0.17 and let me know if you will have any question or problem.
