I would like to have the comment to be hidden when the associated Text annotation is set to hidden, but keep the open state the same.
I tried to change Visible to false, but that does not affect the comment.
For example if the comment is open, and I set the associated text annotation to hidden, I would like both the text annotation and the popup to be hidden, but the pop up state to still be open.
The reason why I want to do this is I want to print the comment in the open or closed state regardless of the hidden state of the associated text annotation.
If the associated text annotatin is set to hidden and the comment IsOpen is set to true, I want be able to print annotation and the comment. If the annotation is set to hidden and the comment IsOpen is set to false, I want to print the text annotation but not the comment.
Is there a way to do this?
