Argument out of range exception pasting annotations.
Post by IntegraHarlan »
I implemented annotation copy paste and I am seeing a Argument out of range exception on the paste operation.
I have tried the implementation two ways.
First I implemented the copy paste functionality similar to your PdfEditorDemo application.
I then implemented the functionality from the annotaion tool CopyAction and PasteAction properties.
Where the _pdfAnnotationTool is PdfAnnotationTool.
The GetUIAction as well as the TryGetCurrentToolActions methods in the GetUIAction method are copied out of the demo app
         // In context menu for copy.
	 CopyItemUIAction copyUIAction = GetUIAction<CopyItemUIAction>(GetAnnotationTool(_pdfAnnotationTool).ImageViewer.VisualTool);
         if (copyUIAction != null)
             copyUIAction.Execute();
         // In context menu for paste.
	 PasteItemUIAction pasteUIAction = GetUIAction<PasteItemUIAction>(GetAnnotationTool(_pdfAnnotationTool).ImageViewer.VisualTool);
         if (pasteUIAction != null)
         	pasteUIAction.Execute();
I also implmented the annotation tool UIActions
        CopyItemUIAction copyUIAction = pdfAnnotationTool.CopyAction;
        PasteItemUIAction pasteUIAction = pdfAnnotationTool.PasteAction;
Here is a stack trace of the error. This happens on the pasteUIAction.Execute:
03/12/2020 9:26:46.496 AM :: ER :: 1 :: VintaSoftViewerControl.ProcessTool :: An unexpected error occurred processing tool 'Paste'. Details: System.ArgumentOutOfRangeException: Index must be within the bounds of the List.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
at System.Collections.ObjectModel.Collection`1.Insert(Int32 index, T item)
at Vintasoft.Imaging.Pdf.UI.Annotations.PdfAnnotationViewCollection.?(Object A_0, CollectionChangeEventArgs`1 A_1)
at Vintasoft.Imaging.CollectionChangeEventHandler`1.Invoke(Object sender, CollectionChangeEventArgs`1 e)
at Vintasoft.Imaging.Pdf.Tree.PdfTreeNodeList`1.OnChanged(CollectionChangeEventArgs`1 e)
at Vintasoft.Imaging.Pdf.Tree.PdfTreeNodeList`1.Insert(Int32 index, T item)
at Vintasoft.Imaging.Pdf.Tree.Annotations.PdfAnnotationList.Insert(Int32 index, PdfAnnotation item)
at Vintasoft.Imaging.Pdf.Tree.InteractiveForms.PdfInteractiveFormEditorManager.?(PdfAnnotationList A_0, IEnumerable`1 A_1, Single A_2, Single A_3)
at Vintasoft.Imaging.Pdf.Tree.InteractiveForms.PdfInteractiveFormEditorManager.AddCopy(PdfInteractiveFormFieldList targetFieldList, PdfAnnotationList targetAnnotationList, IEnumerable`1 annotations, Single offsetX, Single offsetY)
at ?.Execute()
at IS.WM.Viewers.VintaSoftViewerControl.ProcessTool(String toolKey, Boolean controlPressed, Object parameter1, Object parameter2, Object parameter3) in D:\GIT\docutrack\Projects\Viewers\VintaSoftViewer\VintaSoftViewerControlToolbarSupport.cs:line 914
I am not sure what is going on here. It looks like the There in some problem inserting the pasted item into the annotation list.
Is there some other functionality that I am missing for implementing the copy paste operations?
Do I need to be doing something with the clipboard?
Re: Argument out of range exception pasting annotations.
Hi Harlan,
Please send us (to support@vintasoft.com) a small project, which allows to reproduce the problem. We need to reproduce the problem on our side.
Hi Harlan,
Have you solved the problem? We still not received the project, which allows to reproduce the problem on our side.
