Rotating Figure on PDF
Post by tplambeck »
Is it possible to add an image to a PDF and rotate it, preferably by grabbing a corner and rotating? I am able to do this with a regular image by adding set degrees of rotation but can't figure it out on a PDF in an image viewer. Thanks!
Re: Rotating Figure on PDF
As I have understood you want to rotate graphics figures on PDF page in image viewer, i.e. rotate figures created by the Vintasoft.Imaging.Pdf.UI.PdfContentEditorTool visual tool. Am I right?
Post by tplambeck »
Yes sir, that is correct.
Thank you for information.
We will add the ability to rotate graphics figures on PDF page in image viewer in 1 week.
In version 9.0.0.17 we have added the ability to rotate rectangle-based PDF graphics figures (Rectangle, Ellipse, TextBox, FormXObject, Image, VintasoftImage) in image viewer. Please use new functionality and let me know if you will have any question or problem.
Post by tplambeck »
Thank you Alex! Just downloaded and will let you know how it works
