Image painting
Image painting
Post by missionRoom »
My project involves showing and hiding the annotation viewer, and changing the focussed image when the viewer isn't visible. If I change the focused index and then show the viewer, the old image displays for a second before the new one is painted.
Is there a way to only draw the new image? I'm using the below method to change the image, and then hide one control and show the viewer.
private void ReloadImage(int index, ImageCollection images)
    this.annotationViewer.Images = images;
    this.annotationViewer.FocusedIndex = index;
    this.axWindowsMediaPlayer.Visible = false;
    this.annotationViewer.Visible = true;
Re: Image painting
Please send us (to support@vintasoft.com) a small project, which allows to reproduce your problem. We will analyze the problem and will suggest you the best solution.
Re: Image painting
Sent a project to support. Thanks, Alexander
Re: Image painting
Sent a project to support. Thank you for the project. We reproduced the problem, improved your code and now project works as expected. Please use changed project and let me know if you will have any question or problem.
