Does the web service need to be located on each client's machine or can it be moved to a server?The local web TWAIN service provides access to the local scanners and it must be executed on the computer, which is connected with scanner.
First, our product is hosted on a server and many different clients connect to it. With the ActiveX Twain solution we were using a single license for the server. Does this mean that we will require a licence for each individual client machine that will be using the web TWAIN service or will a single server license be sufficient?You need the Single URL license. More info please read in the license agreement: https://www.vintasoft.com/vstwain-dotnet-license.html
Second, can you let me know where I can find the installer for TWAIN service on a local computer?Installer for web TWAIN service, which is based on Web API, can be downloaded from this link: https://www.vintasoft.com/zip/VSWebTwainService1_2.zip
Will the installers for web TWAIN service work on 32 and 64 bit machines? What about different versions of Windows?Our "standard" installer can work in different versions of Windows (Microsoft Windows XP, Vista, 7, 8, 8.1, 10 (32-bit and 64-bit); Microsoft Windows Server 2003, 2008, 2012 (32-bit and 64-bit)).
